![]() | Home > Technical > Help please - difflock problem! |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8205 ![]() ![]() ![]() |
glad the cause was found.
correct, you dont need to take swivels apart of pull brake lines off to remove wheel stations sufficiently enough to get a diff out. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17698 ![]() ![]() ![]() |
A couple of photos of the broken diff, in case anyone is interested. Note that the hole for the cross-pin is worn to the extent that it is nearly two diameters in the direction of thrust. Final failure came when the pin sheared allowing the two differential pinions to move. In the second photo the sheared pin can be seen, together with the well-mashed teeth of the differential gears.
Having now done the normal weekend mileage of 350 miles or so since fitting the new diff, it is clear that the improvement is incredible, perhaps not surprising given the state of the old one. What has surprised me though is the improvement that the new diff has made to the gearchange, which (even after the new clutch was fitted earlier in the year) was clunky and pretty horrible. Now for the first time the gearshift is almost as smooth as a normal vehicle. I really hadn't expected this! If you are one of those unfortunates who has tried all the normal remedies for a clunky and horrible clutch/gearchange and still not found the problem, it might well be worth checking for driveline and/or differential wear. Also, given that my vehicle hasn't (as far as I know) ever been systematically abused, and yet the diff has failed in this way at 87k miles, if you have a 90 or an early 110 with the 2-pinion diff you may want to consider popping the diff out to check it in case it has this advanced wear. ![]() Click image to enlarge ![]() Click image to enlarge |
sound advice, cant believe the state of that after the mileage. have you owned it from new? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
No, I am the fourth owner, but the first two between them had it for about 20k miles and 2 years. After that a very good friend of mine bought it and ran it for a year and approx 30k miles, but during this time I drove the vehicle regularly and I know how it was treated (I also carried out the routine maintenance on it, and oversaw servicing etc) So, unless it was monstrously abused in the first two years, it has had no particularly unusual treatment. The oil level in the axle was correct when my friend bought it, and there was no metallic debris visible when I first changed the axle oils not long after. Having said that, though, it is a bit of a mystery. I have seen many diffs from series Landrovers, including Series Ones, which are essentially exactly the same design and which have been much older and far, far higher mileage, which have been in perfect condition. Admittedly the engine power and torque is much higher on a Puma, and it is unlikely that earlier Landrovers would have been capable of the sort sustained high speed cruising that a Puma can manage (although my Series 1 86", with 2286cc engine, overdrive, etc can cruise at 70) but even so I am surprised at the extent of the wear. It seems likely to me that most of the wear occurred first, then the pin sheared and the diff seized almost immediately after the pin sheared. I cannot think of a plausible failure scenario involving the pin shearing, then the wear, then the seizure. I think there must have been a considerable period when the pin was rotating in the differential carrier with one bevel gear seized to it, rather than the two gears freely rotating on a fixed pin. All a bit strange. At least the outcome is that I now have a far superior diff fitted! |
there was a bad batch of diffs on some of the very early vehicles.
wear first then the failure, no question. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
