![]() | Home > Puma (Tdci) > Engine Temperature dial broken? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20759 ![]() ![]() |
Might be a failed CHT Sensor, they aren’t expensive but worth changing and I think it might be the likely cause of the issue.
There is no guarantee it is, but that’s my thoughts. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3536 ![]() ![]() ![]() |
https://www.defender2.net/forum/topic48874.html?view=previous
That post might help. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6662 ![]() ![]() ![]() |
Does everything else work ok - RPM, warning lights?
Another thing worth checking is the cluster electrical connector to the rear is secure as well, but I think CHT is more likely, but no guarantee it is. WeWillWin🇬🇧🇺🇸
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1393 ![]() ![]() ![]() |
Mine did that a little while ago - but it also wouldn't start either. Turned out to be a relay under drivers seat. Euro-Leafing to infinity and beyond.....
andycam82 Member Since: 01 Feb 2020 Location: Bangor Posts: 25 ![]() ![]() ![]() |
Thank you for all the replies.
Yes everything worked as normal bar the hand brake light as well. Well a nice surprise is that it sorted itself out after a couple of days. The dial went back to the bottom to its normal position. It now works as expected, coming up to temp as normal. Doesn't exceed the halfway point. Hand brake light still not working though! Got to love Defenders. |
