![]() | Home > Maintenance & Modifications > Which Way Do Rope Hooks Go? |
GeorgeE Member Since: 10 Feb 2025 Location: Wanborough Posts: 15 ![]() ![]() ![]() |
On my S111 it is pin closest to the door (i.e. rivets to the rear) so assume it would be the same on a 110.
Now I should add I have no idea if mine was a soft top from the factory, but the hood (both the one it came with and its later replacement from Exmoor Trim) fits fine so I think it is correct. ![]() Click image to enlarge |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 530 ![]() |
On my factory 110 rag top the hook goes closest to the door shut - as per this pic on the Series 3 ^
Michaels Defender Member Since: 16 Aug 2007 Location: North Yorkshire Posts: 278 ![]() ![]() ![]() |
It would make sense to have the pin to the door as I guess you can get the canvas more taught🤷 JE Zulu 110 now sold
Carpathian 110 also sold Defender 110 camper now in build |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6163 ![]() ![]() ![]() |
^^^^ or "less loose"
Slideywindows Member Since: 09 Sep 2016 Location: North Essex Posts: 1303 ![]() ![]() |
I have a 1984 factory, civilian soft-top Ninety.
(These were only available from the factory under special order - most you see are later conversions or ex-military). I don't know if One Ten/110 soft tops were the same, but the photos might help. ![]() Click image to enlarge ![]() Click image to enlarge |
Thanks for the info, rivets nearest to the door
![]() Carpathian 110 also sold Defender 110 camper now in build |
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 224 ![]() ![]() ![]() |
The JLR parts diagram (item no.12) seems to show it is hook towards the door.
This:-
Looks like hooks to the door edge👌 JE Zulu 110 now sold
That's interesting, as mine was factory fitted.
I notice that in the photo above, there is no curved scallop at the bottom of the front edge. It just goes straight down, unlike mine. But there's no accounting for Land Rover! |
