![]() | Home > In Car Electronics > GLOHH lighting system for Defenders |
TrvMac74 Member Since: 17 Mar 2025 Location: Cape Cod Posts: 4 ![]() ![]() |
Does anyone know what headlights the white defender on the Glohh adds?
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 834 ![]() ![]() ![]() |
if you email there support email, they maybe willing to tell you, I think the car is from Iceland Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
I did that last week and they wouldn’t tell me due to liabilities seems odd
They were very dark/smoked that’s what I’m looking for. I’m in the US so tough to find anything local for these Defenders
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1227 ![]() ![]() ![]() |
Aren't they just standard 7in like fitted to beeps?
Yes they do but as mentioned just curious what these might be as haven’t seen them in The US
Shirty Carpet Member Since: 10 Nov 2013 Location: Essex Posts: 29 ![]() ![]() ![]() |
For those that have fitted the fronts, how did you do it?
For the offside, on my 2015 MY XS, I can just about reach through the wing top cover but that doesn’t seem to be an option on the near side because of the heater ductwork. I did try removing the headlight but there’s no way I could see that I’d be able to re-fit it with the headlight surround in place. The wheel-arch liner doesn’t look to have any give in it to allow me to loosen a few fixings and get my hand inside there. A search elsewhere suggests the wing has to come off to remove the liner - seems a little drastic for what I’d hoped to be a simple job. Am I missing something obvious here? |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
You need to remove the wheel arch spat to access the gap between in inner and outer wing
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
mmddbb Member Since: 15 Sep 2021 Location: UK Posts: 18 ![]() ![]() |
In case it is of interest to fit the fronts I 3D printed in ABS some plugs to replace the existing light/body plugs. These screw on to the threads of the Glohh lights and then push in to the body, which makes fitting a 30 min job as opposed to a couple of days if you have to remove arches and fiddle about in the wheel arch. Easy to fit, easy to remove and should work with standard light surrounds.
That sounds very interesting. I’ve no access to a 3D printer but if this is something you’d be prepared to print for me then please DM me and let me know cost etc.
Of course, PM sent
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
