![]() | Home > Group Buys > Td5 Rev Counter |
GerardTd5 Member Since: 03 Aug 2016 Location: almost Germany Posts: 44 ![]() ![]() ![]() |
![]() Click image to enlarge I found this picture on the German Blacklandy website: http://www.blacklandy.eu/blboard/forum/sho...ve-Einbau. Maybe it is vdo by Croytec. Gerardhttp |
GI_Joe_Defender Member Since: 07 May 2023 Location: Suffolk Posts: 7 ![]() ![]() |
I am also interested in a TD5 rev counter.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1182 ![]() ![]() ![]() |
https://www.lrparts.net/yae100790-rev-coun...pment.html
Can you not just get one from one of the retailers? |
jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 181 ![]() |
Bit late to the party, but that's a VDO cockpit vision rev counter: https://vdo-webshop.nl/en/tachometers/1306...00285.html You should be able to take a feed from the unused RPM output pin on the TD5 ECU to feed the VDO gauge. The VDO has settings for number of pulses per revolution, and from what I remember one of them matches up to the number of pulses the ECU outputs. |
