![]() | Home > Td5 > AC fan running when not requested |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 642 ![]() ![]() ![]() |
Take a diagnostics equipment and look for faults in engine ECU. Probably some logged overheat fault. Clean it. This is standard TD5 behavior to switchnon the electric fan after overheat to protect the engine. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
I can confirm as I've just had this on mine after a full rebuild. I must have had the ignition on at some point with the coolant sensor unplugged.
Any fault relating to the cooling system will make the ECU request AC fan until the fault is cleared. Erased all of the faults on mine and no more constant fan ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5820 ![]() ![]() |
Thanks both for your input, but not the case for me. No faults showing on nanocom had checked it before but just checked again, and still clear.
Typically though, no fan running today. |
Noticed it running again today. Checked nanocom. Not ecu faults. But nanocom shows AC Fan requested. Even though all switches off.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1156 ![]() ![]() ![]() |
There was a very recent discussion here I recall where a person had the AC fan running without there being a demand and it was concluded that after an overheat event the ECU plays it safe and kicks in the fan. I think was resolved by clearing the codes.
Does not explain the compressor though so maybe not going to be that simple. |
Yes. That is correct, but I have no codes, and temps all read ok.
Puzzling |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2195 ![]() ![]() |
Your coolant temp switch connected/working correctly?
The AC fan will come on if the ECU thinks theres even a chance of over heat, inc if the coolant switch is broken/ not connected. Instagram @defender_ventures Empire Tuning - Agent |
Yep temp gauge and temp on nano both all good.
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 561 ![]() ![]() ![]() |
I had this recently and it was a dry joint in the air con control box that sits behind the 2 switches, I stripped the unit and re-soldered the joints and it was sorted.
But even if there isn't a fault showing in the ECU, clear the faults anyway, if it was an overheat it doesn't show a code but needs clearing to stop it. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
