Home > Td5 > AC fan running when not requested
landy andy
Got an issue where my AC fan is running when my AC isn’t being used (don’t really use the AC).
I know the fan can be used to cool the engine if the ECU thinks the engine is too hot, so gets the AC fan to help, but mine is coming on as soon as I start the engine, even when minus temps. Most of the time I can then briefly run the AC, then when I turn off the AC the fan also turns off, and I think that is it till next time.
Drove a couple of hours Friday and when I got to destination AC fan running. My engine temps never even get to mid position, and all cooling system runs well. Today on way back stopped at fuel station after an hour, and fan running. This time operating the AC, then AC off, doesn’t stop the fan running. Pulling the relay did though.
Any thoughts?
Post #1061148 23rd Feb 2025 3:26pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Take a diagnostics equipment and look for faults in engine ECU. Probably some logged overheat fault. Clean it. This is standard TD5 behavior to switchnon the electric fan after overheat to protect the engine. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1061187 23rd Feb 2025 10:04pm
grafty99
I can confirm as I've just had this on mine after a full rebuild. I must have had the ignition on at some point with the coolant sensor unplugged.
Any fault relating to the cooling system will make the ECU request AC fan until the fault is cleared. Erased all of the faults on mine and no more constant fan Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #1061258 24th Feb 2025 6:56pm
landy andy
Thanks both for your input, but not the case for me. No faults showing on nanocom had checked it before but just checked again, and still clear.
Typically though, no fan running today.
Post #1061311 25th Feb 2025 10:47am
landy andy
Noticed it running again today. Checked nanocom. Not ecu faults. But nanocom shows AC Fan requested. Even though all switches off.
Post #1062048 5th Mar 2025 9:33am
TexasRover
There was a very recent discussion here I recall where a person had the AC fan running without there being a demand and it was concluded that after an overheat event the ECU plays it safe and kicks in the fan. I think was resolved by clearing the codes.
Does not explain the compressor though so maybe not going to be that simple.
Post #1062073 5th Mar 2025 2:28pm
landy andy
Yes. That is correct, but I have no codes, and temps all read ok.
Puzzling
Post #1062096 5th Mar 2025 6:39pm
bankz5152
Your coolant temp switch connected/working correctly?
The AC fan will come on if the ECU thinks theres even a chance of over heat, inc if the coolant switch is broken/ not connected. Instagram @defender_ventures
Empire Tuning - Agent
Post #1062103 5th Mar 2025 7:33pm
landy andy
Yep temp gauge and temp on nano both all good.
Post #1062115 5th Mar 2025 8:35pm
