Home > In Car Electronics > Speaker upgrade, worth it?
HuddyM
United Kingdom 2009 Defender 90 Puma 2.4 CSW Stornoway Grey
Hello!
I’m considering replacing the stock speakers in my 2009 TDCi. I know very little about “ice”, I have a cheap temporary single din apple car play stereo. But no amp or sub etc.
Is it worth putting something like the Focal AC 100’s in before an amp and sub? Would it make a noticeable difference? I hear the 4” slots in without issue, with a 5” needing an adapter. Is that correct?
Mike
Post #1061164 23rd Feb 2025 6:49pm
Yes, it’s worth it, but the upgrade is limited unless you do a full install.
The factory speakers are very poor though, so even an upgrade on those is beneficial.
But as you are aware, then the HU is the limiting factor without Amped power.
It mainly depends on what sort of expectations you have and what you’d like to spend.
You can get a decent upgrade for some money, but to upgrade a lot then it can get costly. TheThunder Rolls🇬🇧🇺🇸
Post #1061172 23rd Feb 2025 7:38pm
HuddyM
Thanks, figured that would be the case. I’m in the process of finishing off sound deadening and re-carpeting. Saw the speakers at £80 a pair and figured I’d stick them in for now. Then once everything else is done potentially look at a double din and some more hardware. 😎
Post #1061177 23rd Feb 2025 8:00pm
L110CDL
I would second that with the Focal speakers
Mr. Green Clayton.
Keeper.
Post #1061275 24th Feb 2025 9:24pm
HuddyM
Haha. Brilliant 😀😀
I’ve got a set coming tomorrow. Just the 100 ACs for the front for now. 👍🏻
Post #1061278 24th Feb 2025 9:34pm
L110CDL
Even just on the front, you will notice the difference Very Happy Clayton.
Keeper.
Post #1061285 24th Feb 2025 10:00pm
HuddyM
That’s what I was hoping. They arrive today Smile
Once I finish the sound deadening in the rear I’ll get ones for the back too.
Thanks everyone
Post #1061292 25th Feb 2025 6:35am
Sound deadening is an improvement in itself, as it reduces ambient noise and resonation.
So that increases perceived dB output from your speakers anyway, which of course is an improvement in SQ as well.
Carpeting, in your case or light foam on top helps as well.
Very Happy
Those specs on those speakers are pretty good for what you can get, pretty much as much as you can get safely from HU power only.
Just beware the HU itself is free to vent heat. Wink TheThunder Rolls🇬🇧🇺🇸
Post #1061358 25th Feb 2025 5:23pm
HuddyM
Thanks, yeah that was project number 5
It went…
1. Security
2. More security
3. Even more security
4. Weep at the bank balance
5. Killmat and closed cell foam
6. Security
7. Speakers 😂
Post #1061370 25th Feb 2025 7:48pm
L110CDL
Liking the order of jobs to do Very Happy Clayton.
Keeper.
Post #1061462 26th Feb 2025 8:40pm
HuddyM
I try not to write it down, as every time I do it’s out of date within minutes. There’s always something to keep you out of trouble 😂 2009 Stornaway Grey Puma Build Thread
Post #1061469 26th Feb 2025 9:00pm
