Home > Puma (Tdci) > Installation of Mudstuff Transmission Tunnel Matting?
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
Has anybody installed one of these in a 2.4 TDCI?
https://www.mudstuff.co.uk/collections/car...tunnel-mat
I'm about to install mine, but I cannot believe the heater assemble needs to be removed to install? I cannot find any installation information and there is nothing on YT. There are for other Defenders but not the 2.4?
Any ideas?
Thanks
John
Post #1060998 20th Feb 2025 6:10pm
jst
Wright off road kit.
No instructions came with mine I fitted it without taking heater unit out. Was a while ago, design may have changed. It's a two person job. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1061000 20th Feb 2025 6:41pm
John P
Yes that’s the one. Can you remember if you cut the tunnel to slip around the back of the heater box? This makes the most sense to me, as there is a score mark on the tunnel mat. Just wanted to see if anyone else had done this.
Post #1061002 20th Feb 2025 6:48pm
jst
it was a while ago but i dont believe i cut it. took gaiters off though. needs two people so thin bits dont rip. keep it warm prior to fitting too. well worth the effort. cant check mine as its under an auto console now. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1061007 20th Feb 2025 7:37pm
bodstruck
I would suggest giving Drew Wright a call to ask about fiting if it is one of his kits being resold. He was very helpful to me when I bought one for my defender.
Post #1061016 21st Feb 2025 7:16am
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
I cut mine also as i realized after I had fitted the heater box and no way was I removing again, to be honest it also leave it easier to move it around later as I have had to do to install more sound deadening
Post #1061022 21st Feb 2025 10:34am
John P
Yes that makes sense, as it would be nice to be able to remove it easily for access to the gearbox etc. if needed. Thanks Thumbs Up
Post #1061027 21st Feb 2025 11:42am
mwestcrew
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Baltic Blue
I didn’t cut mine but it was a bit of a mare and a two man job because of the weight.
Seats out to give room for manoeuvre
Worth every second of the struggle though. Makes a huge difference. 2011 130 Utility Body
2005 110 Van
Post #1061302 25th Feb 2025 9:09am
John P
Got mine fitted last night. It has to be cut, unless you take the heater box out, which I wasn’t prepared to do. It went in fairly smoothly.
Post #1061306 25th Feb 2025 9:35am
