Home > Modifications & Maintenance (L663) > Mirror Clearsight retrofit
Page 8 of 8 <12345678
Colin68
I did as ThunderBob says. I didnt buy the land rover cable. I bought a Fakra Cable of Amazon for around
£7
YILIANDUO Fakra Z Female to Female Car Vehicle Aerial Antenna Extension Cable RG174 1.6ft 50CM for Car Stereo Android Head Unit GPS Navigation FM AM Radio Sirius XM Satellite Radio
It worked perfectly!
Post #1060828 18th Feb 2025 8:08am
isugoo
United States
Thanks! I will skip the LR cable.
So your connection is:
Mirror > Fakra cable (50 cm) > Camera/cover.
That seems like do-able with my skill set. =D
Post #1060829 18th Feb 2025 8:24am
Darrant1234
You just need a female to female cable. I used a 5m in my 110 it’s too longs but works.
https://www.ebay.co.uk/itm/226306351839?mk...media=COPY
Post #1060899 18th Feb 2025 11:24pm
isugoo
United States
Got it. I read entire threads again and got the idea that LR164584 is basically converting Female to Male connections. So if I buy Fakra Female to Female, I can eliminate and connect mirror and the camera with just one cable. For my Defender 90, I ordered 6 ft (1.82 m) female to female. I hope the length and connection works.
As I now fully ordered all the parts, I'll report back once I have all parts and installed. Thank you everyone for supporting my project!
US Spec Defender 90, these are the parts I ordered:
• LR1403340 Smart Mirror with Home Link - used from US 110 donor car
https://www.ebay.com/itm/375814666311
• LR140535 Fin Camera (US specific) - suppose to come with the cover
https://www.ebay.com/itm/386774670497
• Fakra Cable Female to Female (6 ft / 1.82 m) - cheap eBay version
https://www.ebay.com/itm/133373277615
Post #1060902 18th Feb 2025 11:44pm
hmgt3
Oman
Mirror housing
Hi. I want to attempt the mirror upgrade. My question is, what is the easiest way to get the plastic housing around the mirror arm off? It feels rather fragile. Don’t want to break it.
Thanks
Post #1061708 2nd Mar 2025 1:02am
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I just used a trim removal tool like the one pictured and just carefully inserted it into the line down the middle of the trim and eased them apart.
 Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1061709 2nd Mar 2025 1:17am
hmgt3
Oman
Thank you. Will try that.
Post #1061712 2nd Mar 2025 6:59am
Colin68
I was a bit apprehensive but it came apart easy.
Post #1061774 2nd Mar 2025 10:03pm
isugoo
United States
I tried to install yesterday but found out Fakra Cable 6 ft / 1.82 m wasn't long enough for D90. So I ordered 10 ft (3m). Will report back buys. Thanks!
Post #1063011 15th Mar 2025 3:06pm
isugoo
United States
Just finished installing it with 12 ft. cable (6 ft. didn't work. 8 ft. maybe tight and 10 ft. would be enough but I just wanted to be sure so used 12 ft. cable) for my D90 and def. fishing wire is the hardest part. Other than that, everything went very smoothly. I coded Clearsight mirror via GAP Tool before install so the second I installed, Clearsight worked right away. Thanks everyone for the support!
Post #1064719 5th Apr 2025 6:43am
