![]() | Home > General & Technical (L663) > Silver / Aluminum Speaker grills |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20688 ![]() ![]() |
You could try asking these guys:
https://jlr-retrofit.com/defender-retrofits-meridian-surround/ Or CSK Automotive. Beyond that a LR Dealer using their parts system. TheThunderRolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 437 ![]() ![]() |
Find your part..
https://landrover.scuderiacarparts.com/par...4877/91367 No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
CincyRovers1 Member Since: 30 Nov 2023 Location: Cincinnati, Ohio Posts: 120 ![]() ![]() |
Assuming the new 2025+ speaker grilles are constructed the same way, then yes, they would be compatible. If that's the case, the midrange grilles are easy to replace, you just pop them off and put the new ones on. Same goes for the tweeters. The only way to remove the bass speaker grilles is to take off the outer door panel and remove the grilles by un-crimping the metal tabs. You'll have to reuse the felt that protects the speaker, too. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar) 𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red) 𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone 𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone |
