Home > General & Technical (L663) > Silver / Aluminum Speaker grills
ElectroGeek
United States
Dose anyone know the PNs for the Aluminum Speaker grills? Are the compatible with 2025 year models?
Post #1060556 14th Feb 2025 4:40pm
You could try asking these guys:
https://jlr-retrofit.com/defender-retrofits-meridian-surround/
Or CSK Automotive.
Beyond that a LR Dealer using their parts system. WeWillWin🇬🇧🇺🇸
Post #1060576 14th Feb 2025 7:56pm
Defendit..
Netherlands
Find your part..
https://landrover.scuderiacarparts.com/par...4877/91367 No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1060581 14th Feb 2025 8:53pm
CincyRovers1
United States
Re: Silver / Aluminum Speaker grills
Assuming the new 2025+ speaker grilles are constructed the same way, then yes, they would be compatible. If that's the case, the midrange grilles are easy to replace, you just pop them off and put the new ones on. Same goes for the tweeters. The only way to remove the bass speaker grilles is to take off the outer door panel and remove the grilles by un-crimping the metal tabs. You'll have to reuse the felt that protects the speaker, too. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red)
𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone
𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone
Post #1060583 14th Feb 2025 9:17pm
