Home > General & Technical (L663) > 3D Bird view issue
Aulus
United States
3D Bird view issue
Does anybody else have similar issues with their clear sight or is this normal. It is either super blurry, or blacked out.
Post #1060082 10th Feb 2025 12:21am
DefenderMidlands
Clearsight is the interior rear view mirror with the screen on working from the rear roof camera? MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
Post #1060085 10th Feb 2025 6:16am
JonathanP
United Kingdom 1998 Defender 90 300 Tdi SW Caledonian Blue
Hi
Clearsight is displayed on your windscreen's rear view mirror, from a camera in the "sharks fin" on the roof, the display you show is from the door mirror, front and rear bumper cameras, and computer generated / interpolated images from such cameras. The view, of which you can select from touching the camera on the left screen to give the picture on the right,
Regards
Jonathan
Post #1060110 10th Feb 2025 12:04pm
Aulus
United States
Oh I thought it was all called clear sight. In any regards does anybody also similar occurrence that the image around the car is grayed out like that? I was trying to determine if that's normal or camera issue.
Post #1060120 10th Feb 2025 1:27pm
XplusYplusZ
Does the problem occur when you're driving, or only when you first jump in the car?
Could it be as simple as the fact that the cameras aren't actually able to see the greyed out sections - the clever software augments the images it's recorded and projects them 'underneath' the vehicle.
When you're moving this is fine, the camera has records of the ground images which it can then augment
beneath the vehicle. But when you first switch the vehicle on, the cameras don't have a record of what's now underneath the vehicle, it can't guess what the ground looks like, so you get a greyed out section..?
If this happens whilst driving slowly, then it's some sort of software glitch.. if it's only when stationary, I think that's inherent to the design of the software.
Post #1060539 14th Feb 2025 12:01pm
Aulus
United States
That makes a lot of sense on start up. When I start to drive it becomes blurry, but not greyed out like that. Almost like looking through a frost window. It's not greyed but it's blurry you can't see anything.
Post #1060540 14th Feb 2025 12:20pm
XplusYplusZ
Mine looks like you describe when the front camera is dirty (which is a permanent feature this time of year!). The side (mirror) cams are out the way so remain relatively clear whilst the rear camera has a cleaning nozzle. So you can end up with crisp images for 270 degrees and a fuzzy forward image..
Maybe give the front camera a squirt of water and a wipe with a soft towel / (some spit and your sleeve!)
Post #1060543 14th Feb 2025 12:27pm
LR Nuts
I once got this , after an on-off switch of engine, it reset itself
Post #1060547 14th Feb 2025 1:38pm
stevemfr
France
I'd do a drug screening with my Defender if I were you...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #1060559 14th Feb 2025 3:44pm
XplusYplusZ
To confirm; I tested this morning and when moving the blank area shown is filled with an augmented image of what's beneath the vehicle.
As you come to a stop, the camera system stops filling in the gap and the blank area you identified comes into view.
When you move off again, the feed from the camera is reinstated.
Post #1060744 17th Feb 2025 8:33am
A1C6
Australia
Re: 3D Bird view issue
That looks like mud on the cameras to me.
Post #1060896 18th Feb 2025 9:49pm
