Home > Off Topic > Chainsaw advice
Page 3 of 3 <123
TexasRover
Muddybigdog wrote:
A blunt saw is a dangerous saw, Stihl does a great little 2-in-1 EasyFile, which is well worth the purchase to keep sharp. I use an Oregon Easy-cut Saw Horse, just for that extra safety.
Agree, bit of sand and you are done. Sure you can sharpen or for the occasional user a new chain is surprisingly cheap and quick to swap..
Post #1060149 10th Feb 2025 7:32pm
RobKeay
L&S engineering sell pretty much every part. I’ve got a saw from the eighties running again with parts supplied by them.
We use ones with a changeable sprocket. You’ll need a new bearing while your at it.
Post #1060153 10th Feb 2025 7:53pm
spudfan
Ireland
I have an electric chainsaw. I have had it for some years. It is quieter than a petrol model but you are restricted by the cable and your extension chord. It is versatile and has cut some substantial timber over the years, mainly fallen trees. It was no good to me during the last storm as the power went. Also you cannot use it when it is raining owing to the electrical connections.
Used within these limitations it works well.Like others have said you must be very careful when using a chainsaw. If it's cutting ability seems to have lessened just change the chain. Keep an eye on the tension of the chain when using it, and keep an eye on the level of the chainsaw oil in the reservoir.
I only use the chain saw for the branches or trunks that are too big to cut by hand. A chainsaw is useless for small diameter branches. These are best done by hand.
I have a wooden sawhorse. I put lengths of carpet gripper strips in the "V" to help grip the branches. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1060507 13th Feb 2025 9:46pm
hank
I have a few Husqvarna XP (professional) chainsaws. Excellent.
From your post it sounds as though you primary need is processing grounded timber so I would suggest you might benefit from two tools...
I don't know how far this timber has already been processed but you will likely still need a chainsaw to process into manageable lengths
But then if you need to ring a fair bit of firewood over extended periods of time then a chainsaw is possibly not the right tool and becomes tiresome after a while.
If you have the space perhaps consider a log saw for the mundane processing work. Something like the below. Easier on the back, less maintenance, quieter, safer...
https://www.lawson-his.co.uk/clarke-340199...&gQT=1
Alternatively since this sounds like a one off then there are often firewood processors advertised for hire on facebook marketplace who will come to your property with a proper automated firewood processor. Might be a more cost effective solution for you. What might take you a week could be boshed out in a day with the right equipment! Some examples below
https://www.facebook.com/marketplace/item/583684980793435
https://www.facebook.com/marketplace/item/491788100489238
https://www.facebook.com/marketplace/item/594780119612786
https://www.facebook.com/marketplace/item/1786149628624572
Remember you will also need a splitter so perhaps a third tool to consider.
All the "men" will tell you that they split by hand but by the sound of it you have a fair volume to get through... Get a splitter > 110 XS Double Cab
Post #1060530 14th Feb 2025 10:38am
Slideywindows
The first supplier I ordered from, took three days to refund my payment, and four days to tell me why - after I had to ask.
Didn't have the chain apparently.
So I remembered this ^ quote (thanks RK) and rang L&S Engineering yesterday lunchtime.
The woman who answered the phone knew exactly what I needed.
The correct chain and guide arrived this morning.
Quite a bit more expensive, but well worth it for quality Husqvarna guide and Stihl chain.
So I'm happy to recommend L&S too.
Just a shame that the sprocket/bearing I ordered from Ransom Spares nearly a week ago, has yet to arrive...... Sad
Post #1060572 14th Feb 2025 7:42pm
spudfan
Ireland
Just like ordering parts for your Land Rover Mr. Green 1982 88" 2.25 diesel
Post #1060577 14th Feb 2025 8:02pm
RobKeay
I am very lucky they are 20 mins from my house. They have never let us down. If you register on their website you get all the Stihl parts breakdowns. Saved my skin quite a few times.
Post #1060589 14th Feb 2025 9:41pm
Page 3 of 3 <123
