![]() | Home > Off Topic > Chainsaw advice |
MOD_Series_III Member Since: 23 Apr 2020 Location: Manche Posts: 14 ![]() ![]() |
I would love a Stihl, but they are tad expensive for the non-professional / farmer.
I bought a £99 chainsaw from Aldi years ago, with a 3 year warranty - it lasted 6 years with zero maintenance. I now have a €100 Leroy Merlin (France) special with a 3 year warranty - it is far superior to the Aldi one, starts first time hot / cold. I also have a Dewalt battery chainsaw (simply because I have Dewalt batteries) it is amazing and I prefer over the petrol one for climbing / ladders as it is only running when I press the button(s). |
Slideywindows Member Since: 09 Sep 2016 Location: North Essex Posts: 1303 ![]() ![]() |
I wonder if I could go marginally off topic, as I've been servicing my Husky 55 today, in preparation of processing some firewood.
I've been using a chainsaw for decades (always Husqvarna) and this one has lasted a very long time. However, the chain is now so stretched that it won't adjust any more. In the process of inspecting it, I noticed that not only have I had my money's worth out of it, but the blade is worn and, more importantly, the drive sprocket is worn - grooved - as well (The engine is fine). So my questions: I know the chain and blade are replaceable, but is the sprocket (easily) replaceable? (I've tried to undo the central nut but failed!) After a life of hard work, would it be a false economy to get it fixed or should I just buy a new Husky, despite the engine being fine? I ask the last question because, as we know in the Land Rover world, famous names often outsource maufacture to the Far East, and quality can suffer. So what are the new Husqvarna's like? All advice will be listened to. (And some of it might even be taken! ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17676 ![]() ![]() ![]() |
Easily serviced and if it's running well a better bet than a new one. The sprocket is a service part and about £15 but remember that the clutch has a left hand thread (perhaps why you couldn't shift it). An impact wrench usually whips it off.
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1333 ![]() ![]() ![]() |
EDIT. Just seen Blackwolf's post about the left hand thread!!!!
Has the Husky 55 got a left hand thread on the clutch/sprocket assembly? If the engine is running well, I'd definitely be looking to replace the sprocket and give the saw a new lease of life. |
Since it's only secured by the thread (not splined to the shaft) then if it didn't have a LH thread it would unscrew as soon as load was put on the chain.
Bowbearer Member Since: 12 Aug 2022 Location: Norfolk Posts: 200 ![]() ![]() ![]() |
LH thread
Take the spark plug out and put the handle of a screw driver in the hole Then give the nut a sharp crack and it will loosen Buy a chain and sprocket as a kit, usually cheaper. Also file the bar. Put it in a vice and draw the file along the length. It vill remove the v and make it flat again. You will be surprised how well it will cut. |
Wow, such helpful replies guys.
![]() (And many thanks for that video, lohr500. ![]() I will be taking all your advice and buying replacement parts. (No wonder I couldn't undo that darned nut!!) |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 530 ![]() ![]() ![]() |
I've had a Husqvarna 357xp for nearly twenty years and it's done a fair amount of work without any problems, until it stopped a couple of years ago.
Needing a quick fix I bought a DeWalt flexvolt with two 9ah batteries. I wasn't sure how it would compare to the professional saw I was used to but for anything other than larger trunks it's pretty much as good. It's definitely slower, but silent, always on, no need to fuel it, simpler to use, lighter and better suited to a domestic/ small holder/ less pressing use. For all day use and speed you can't beat a petrol saw though, but all of my power tools use the same batteries too, which I'm using most days, so that's a benefit. I'd buy a battery one and a cheap petrol one for the bigger stuff if you need it and keep the battery one in particular very sharp. 1983 110 automatic OM606 |
Bows Member Since: 07 May 2012 Location: Wales Posts: 520 ![]() ![]() ![]() |
I would buy a second hand husky or stihl, and buy as big as you dare, I’ve wasted so much time cutting with a cheap saw. They can be underpowered and take an age to get through a modest size round.
Plenty of decent safety and use videos on YouTube. 2006 TD5110 station wagon 1995 300Tdi 90 truck cab 1989 90 hard top with 200 tdi 1983 110 hard top 1983 110 Hi cap 1954 107 pick up |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2217 ![]() ![]() ![]() |
Actually may make sense as would leave me time to do other things more specific to my own skill set……. Thanks for all advice / ideas and will update over the next few months as we get things moved forward |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1591 ![]() ![]() ![]() |
Depends on your budget. We use stihl both electric and petrol.
The ultimate being a 500i that’s a beast but over a grand. All rounder is ms261 be around £700 Don’t over look electric/battery stuff especially if you already own batteries. When people say service a saw there’s nothing you can’t do yourself. You should be doing a lot each use, they are high maintenance. |
Muddybigdog Member Since: 11 Apr 2014 Location: Suffolk Posts: 1033 ![]() ![]() ![]() |
A blunt saw is a dangerous saw, Stihl does a great little 2-in-1 EasyFile, which is well worth the purchase to keep sharp. I use an Oregon Easy-cut Saw Horse, just for that extra safety. Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold D3 - 2.7 S x2 (both Sold) Freelander 2 HSE - Sold Freelander 1 - Sold Disco 2 - Sold |
s55shh Member Since: 30 Dec 2019 Location: staffs Posts: 199 ![]() ![]() |
I too have a dewalt battery one (because I've got other dewalt tools - same battery) and often use it when I don't want to make loads of noise with the Styhl. Also got a corded extended pole chain saw for trimming high branches so can cover most requirements with the three.
Well, the sprocket came off.
Picture shows the wear after 30 years. Could only find one replacement that guaranteed to fit an old Model 55. (Using a part number found online). £47ish, inc postage. ![]() Click image to enlarge New chain and bar ordered too. I also bought this a few months ago. Used for lopping, I've been working it hard (also bought two spare chains). ![]() Click image to enlarge It is one of those tools where you wonder why you didn't buy it years ago. |
