![]() | Home > Puma (Tdci) > Puma 2.2 Starter only turns sporadically below 10 degrees |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2259 ![]() ![]() |
The one thing you have not mentioned is the starter battery . Is it the original, if not how old is it ?
If not the battery I would check the major earths and the correctness and torque of the battery terminal clamp connections. |
TobiOcean Member Since: 07 Feb 2025 Location: Braunschweig Posts: 4 ![]() ![]() ![]() |
Oh sorry, the Battery is brand spanking new. The battery poles are clean, sit correctly and firmly. I checked every ground connection I could see and reach.
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 687 ![]() ![]() |
Hi... you may have been down this route , but start by monitoring the supply to the starter relay when you turn ignition to crank.. is it operating ..if it is are you getting that voltage at the starter motor solenoid ..etc etc..
If the fault is consistently there at low temp it should be possible to check each component in the chain with a meter.. and take it from there..๐ |
Thanks, yeah I have tried that but at the actual Temps it Starts within the 1maybe 1 1/2 second window which makes that attempt really hardโฆ
Yes, see what you mean , but I'd still be inclined to see if the starter relay is been energised when you turn ign to crank.. it could be done with a bit playing..with a bulb to its output and have it visible when you go to crank..
It about finding out at what point or component the system is failing at.. I now and again get the no crank, when I turn the key.. I've never established a cause .it's fairly random and not very often.. I suspect that the immobiliser isn't letting the starter relay ground...that's just a guess , but if I wanted to I would do something like I described to see if in fact the relay was getting actuated.. This all assumes you know that the power switching circut of the relay is good.. ๐ |
So, after I meticulously cleaned all ground points with the electric file, sandpaper, Vaseline and key files and replaced the main ground cable of the battery with a new one, the error was still there.
So I started to measure, when I wanted to measure under the speedometer on the ignition switch, the white/red cable (starter relay) came off from the ignition switch with only a light tap. So cable lug on it, pressed with the pliers and look, even at -4 degrees without even a second of delay started. 5 months ago I installed a cruise control, the wiring harness runs close to the ignition switch - I must have pressed too badly when assembling it. Well, I book the spare parts under prophylactic maintenance. And thanks for your input! |
