Home > Technical > Electrical wiring help needed if possible |
luccie_007 Member Since: 06 Jan 2025 Location: Buchten Posts: 4 |
Hi,
Electrician here, voltage does not always mean there is current flowing (Amps) So put your multimeter in the AMPS mode, and wire it inbetween the battery. It might just be an open circuit or residual voltage. https://www.wikihow.com/Measure-Amperage Simple but effective how to. Of there is no current flowing, there is not a real issue. First test this with OFF, and then with the LEAST hot stage, as your multimeter might not cope above 10Amps, which might be used in the hottest stage. |
3rd Feb 2025 10:20pm |
110Matty Member Since: 20 Apr 2023 Location: Somerset Posts: 140 |
Thanks for the reply, I did wonder if there was something like this that could be going on. However, i got over it by connecting the modules switched 12v and the permanent 12v wires together, so that no voltage / current would be in play until i switched the dash switches on. I wanted to keep the OEM dash switches operational (as I'd installed them as a retrofit for the single stage heated seats that I've just removed), so I now switch from the dash, via a relay to the new seats loom/module and the aftermarket switch to control the 3 stage heating. I can confirm that stage 3 gets very warm, too warm for long periods, so I'm glad of the lower heat settings. Had I stuck to using the OEM switches alone, wired directly to the seats, I think I would have only had off, or stage 3, which isn't what I wanted. Cheers. Defender 90 TD5 2004
4th Feb 2025 11:25am |
