![]() | Home > Puma (Tdci) > Towing Electrics & Leisure Battery Charging |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 625 ![]() ![]() ![]() |
My understanding is that you could, but only a small number of amps can flow down the weedy wire. I have big fat cables going to an anderson connector, but that charges 2 x 12v batteries that could be completely flat after a few days, so need more amps.
m7ble Member Since: 24 Apr 2023 Location: Lancashire Posts: 20 ![]() ![]() ![]() |
Weedy wire
![]() That’s exactly what I was thinking, why is it so thin as it kinda makes it redundant but it was probably sufficient 10 years ago. This is the last part of the puzzle I need to solve. I’m trying to make the overland trailer future proof and even maybe tow it with the wife’s car so I need to come up with a solution. The trailer will have a 240v hookup and also solar, I’ll get about 5 days off the leisure battery which will probably be enough, and if we moved campsites it would get a top up whilst being towed. |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1111 ![]() ![]() ![]() |
I also thought the "S" was introduced to do just that and the 13pin was just a more convenient merge into one plug. There are separate ground wires that match the respective 12V wires to take care of the amps, but I wouldn't use them for more than 10A each.
