Home > Td5 > Strange and worrying noises |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5792 |
I would start with dropping the diff oil, checking that and also the diff via the fill hole.
3rd Feb 2025 9:08am |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1121 |
If the sound is directly related to roadspeed and there is no change coasting clutch in or neutral or with transfer in neutral then you are left with the transfercase output shaft, the prop shafts, diffs, cv, and bearings.
I agree drain the diffs and look at that first. Bearings are quick-ish to inspect. Propshafts you should feel, in fact I would check for play in the TC output shaft and diff pinions. CV joints can be pulled fairly easy too. |
3rd Feb 2025 10:09am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17556 |
The front diff is a notorious weak spot, especially on a 130. I would drop the oil as a matter of urgency and also see what you can see through the filler hole. It is no fun at all if the diff or axle locks solid at speed!
3rd Feb 2025 12:34pm |
