Home > Maintenance & Modifications > sticky number plate removal
falkster
Germany 1988 Defender 110 V8 Petrol CSW Trident Green
Hi all,
previous owner installed one of those sticky number plates on the flap when he installed the winch and winch bumper.
I want to revert to original bumper as realistically I will never use the winch and even if I might some day, I do not fancy carrying a winch with me all year round on the off chance i might need one. In addition, I prefer the look without the winch (so my winch and bumper will be up for sale later if someone wants them).
What is the best way to get the number plate of the flap? Anyone done this and has a successful method?
Thanks for any advice.[/img]  1988 Land Rover OneTen County SW, 3.9l Petrol V8 (serpentine), original "Santana" LT85 gearbox
Post #1059263 2nd Feb 2025 12:31pm
Balvaig
Never removed one from there, but I normal heat up the plate with a hairdryer and then use thick dental floss between the plate and surface to prise it loose.
Take your time, do a small section from the narrow end working inwards towards the centre. Use plastic wedges when you have loosened a section to stop it reattaching.
Post #1059267 2nd Feb 2025 12:48pm
falkster
interesting. This advice is more for a physical number plate?
My topic tuitle is misleading. This is literally one of these reg number stickers but i guess the gentle heating and work across method is equally applicable(?).
I was just wondering if for these stickers they use a different (stronger?) adhesive.
Thanks for your response!  1988 Land Rover OneTen County SW, 3.9l Petrol V8 (serpentine), original "Santana" LT85 gearbox
Post #1059278 2nd Feb 2025 1:54pm
Balvaig
Yes, advice was for double sided tape on metal or plastic plate.
Hard to know what adhesive may have been used on yours. Still worth trying heat and then peeling back a corner if possible. Most adhesive is at its weakest if you are pulling away at about 90 degrees from flat.
Solvents are a problem as you need to get under the plastic and some can damage your paint.
As a last resort you will probably get it off with a window scraper, but will damage the paint. Amazon sell a double edged scraper with metal and plastic blades. The plastic blades may limit the damage.
Very much trial and error I am afraid.
Post #1059285 2nd Feb 2025 3:17pm
Karl12345
United Kingdom 1997 Defender 90 300 Tdi HT Nato Green
Hi
I used some really strong nylon line that cut though ok assuming it’s not mastic that’s holding it on 👍
Post #1059286 2nd Feb 2025 3:22pm
Ianh
Heat from hair dryer / heat gun to soften the adhesive and a slow gentle pull as heat is continuously applied to the pulled edge. Then cleanup with some isopropyl alcohol. Then wash paint down, polish and then wax.
Don’t rush on the pull, let the heat do it’s work. A hair dryer will probably be best as heat guns can give too much heat. Having a cheap Infrared Thermometer gun helps to gauge temp applied, especially if using a heat gun. They are also useful for reading engine temp, coolant pipes temp etc so useful for other applications.
Post #1059294 2nd Feb 2025 4:38pm
Hairdryer is much safer than heat gun, the latter gets often far far too hot for sure.
A toffee wheel is ideal for residue if rubbing alcohol doesn’t move it.
Is this plate a plastic one which has adhesive holding it on? Or is it like a sticker stuck on on like a decal would be?
Looking at messages, assuming it is a sticker type by the looks of it, so you can try and take off as much of it as you can as others have suggested, if any small bits email off a toffee wheel will do it.
Finish of with rubbing alcohol.
After a little while you might want to wax the paint, but you might still have witness marks there due to UV but in that location I don’t think you’d notice much really. WeWillWin🇬🇧🇺🇸
Post #1059314 2nd Feb 2025 8:13pm
