Home > General & Technical (L663) > Newbie GAP success, but some questions |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 232 |
Good topic opened, maybe it is the step for other "newbies" to decide to take the longed-for step, I will be attentive to your concerns and their answers. Thank you Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
14th Jan 2025 3:49pm |
Zeke Member Since: 02 Oct 2024 Location: New Jersey Posts: 3 |
Yes, I am an old school car guy. Give me a set of SU carbs to rebuild and not a problem, but this computerized stuff is daunting. I will say with some research, YouTube videos and just following the steps slowly on the GAP tool I was quite proud to have had success. Just not sure about the “multiple step” operations with the GAP tool.
14th Jan 2025 3:58pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2672 |
I'm in the same boat. I've had my tool since before New Year, but it's still sat on the coffee table. Not plugged it in or done anything with it. 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
14th Jan 2025 3:59pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2688 |
You can change multiple values in one operation no problem. Just keep a note of what you’ve changed each time.
14th Jan 2025 5:00pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2917 |
I believe the GAP tool stores the original settings so if you mess up, you can just hit "RESTORE" and everything will go back to factory settings.
14th Jan 2025 6:26pm |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 109 |
I've mentioned this in other threads. You can email your complete CCF to yourself. I did this before my first modification, and after every modification since, as well as any time the vehicle is in the shop. A good text compare utility can help you keep track of what has changed.
14th Jan 2025 6:33pm |
DC-Defender Member Since: 23 May 2024 Location: USA Posts: 9 |
This is the way. Email yourself a copy of the CCF before performing changes so you can later compare it to your current one (post changes) if you ever want to change back a previously changed setting, instead of doing a full restore of the CCF to the original configuration backup the GAP tool takes when you first plug it in.
I email a copy of my CCF before every change, and I used NotePad++ with the ComparePlus plugin to compare the two. |
30th Jan 2025 2:28am |
Eric Caterpillar Member Since: 17 Jun 2024 Location: West of Scotland Posts: 65 |
I've just received my new GAP tool and went straight to check it with the car. Do I need to do something in the app explicitly to make it save the original CCF file, in case I need to restore it back to the factory spec? |
31st Jan 2025 1:55pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 |
The tool automatically saves you original set up so you can revert back to it at any time Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
31st Jan 2025 11:40pm |
Thank you for confirming this for me Hairy Dan!
2nd Feb 2025 12:10pm |
