Home > In Car Electronics > Wolfbox rear Camera
jst
Wolfbox rear Camera
Has anyone tried one of these of have experience of a reliable hard wired rear camera with a screen that goes over the top or replaces the interior mirror?
Such as
https://www.ebay.co.uk/itm/175876383148 Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1057874 19th Jan 2025 5:44pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Not a wolf box but have fitted a very similar type dash cam/mirror from Amazon, think it’s called jansite.
I believe most of these lower priced camera mirrors are basically the same.
Fitted it to our freelander 2.
It’s only been fitted a couple of months and can certainly recommend. It’s hard wired in and all the cables are hidden out of sight.
Touch wood, it’s been faultless. I’ve got it set up so the rear cam feed is always showing when driving so is kind of like clearsight on the newer models but has slightly wider field of view and the screen allows you to scroll down the view for the added benefit of the use as a reverse camera with just one camera.
I like it so much, I’ve just bought a very similar one for my 110. This one is a Pelsee and has a gps speed readout on the screen also.
I’ve already got a reverse camera set up on my Defender so this is essentially just a rear view camera/front/rear dash cam, which in my case is an upgrade as my vehicles tend to be full of stuff/dogs and I can now actually see out the back!.
The only downsides with both of them is that the sunvisors hit them when they’re dropped right down as they’re bigger than the standard mirror (both my cams are the 10inch versions) and the camera is on the passenger side of the mirror so the front camera view favours the near side ever so slightly but the field of view is wide enough to cover enough of the front of the vehicle.
Post #1057896 19th Jan 2025 7:31pm
jst
Cheers, hadn't thought on sum visors, will check those other makes. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1057932 19th Jan 2025 11:41pm
24heuer
Scotland 2010 Defender 110 Puma 2.4 CSW Keswick Green
I was given the Wolfbox g900 for my Puma from the family for Christmas.
The rear camera is great as a mirror - I hadn't realised what a whole new world I'd been missing before.
With the dog guard and tinted glass I'd been relying on the door mirrors.
I fitted the rear camera inside the rear door stuck to the underside of the brake light.
I didn't bother hooking it up to the reverse light as I already had a Garmin rear parking camera on my satnav - plus the wolfbox field of view is pretty large and using your finger on the mirror you can scroll the mirror view up and down to see further down (does that make sense? Smile)
My rear window is tinted and doesn't seem to affect the camera.
I got the ODB cable with mine so it draws it's power from there.
There is an inline switch to select a minimum voltage before it stops the time-lapse recording when the vehicle is parked.
However I have mine set to the maximum and I think that function could be draining the battery too far.
It is possible to disable this parked mode feature.
One of my boys got one for his Golf and that instead has the wiring to the fuse box with a couple of piggyback connectors.
His doesn't have this issue.
It also comes with a gps antenna on a stupidly long cable - I've left mine in the box.
I guess if you wanted the full dash cam features to record exact time and location of an incident it should be fitted.
The front camera is 4k btw and is fantastic - you swipe left or right to switch between rear/front/combined views.
I've not experienced any trouble with mirror blocking the sun visors other that the mrs ramming the thing out the way without notice to get the visor down Very Happy
It hooks onto the existing mirror so you can still swivel it about.
In summary I'm enjoying mine as a rear view mirror.
I've not bothered with any of the dash cam stuff yet due to time.
I need to investigate the ODB lead to see if the minimum power selector is set correctly before I try Parked mode again.
Oh and it's pretty big and initially I thought it would obscure too much of the windscreen but it seems fine.
The instructions are rubbish also and translation to English is awful in places - from the ads I'd thought it was from the US but it's probably Chinese. Cheers,
Andy...
Edinburgh, Scotland
http://24heuer.com
Post #1057944 20th Jan 2025 9:22am
jst
thanks Andy thats great, battery drain to consider then. guess it could always just be unplugged. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1057986 20th Jan 2025 2:06pm
24heuer
I noticed on YouTube grizzlyandbear use the dash mount for their's which leaves a great view out the windscreen -
 Cheers,
Andy...
Edinburgh, Scotland
http://24heuer.com
Post #1057998 20th Jan 2025 4:10pm
BuckBlu110
They’re supposed to have a voltage sensor which cuts off to stop battery drain. Neither of mine have drained the battery as of yet but I haven’t played with the settings for the time lapse lot yet.
I removed my standard mirror all together and mounted the new one on a suction cup job from Amazon. https://amzn.eu/d/83E9h1N
I fitted it as high up the screen as possible. That put the mirror much higher. The aim was to avoid the sun visors but it only improved range of movement slightly.
I’ll try and get some pictures as and when I can.
Post #1058009 20th Jan 2025 5:56pm
jst
Some pics would be great, especially of camera view and where you have e installed it. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1058081 20th Jan 2025 10:15pm
mcma1
Glad this thread got started. I have the LR single din Sat Nav unit as I am not a fan of the double din but it doesn't support a rear camera. So I was planning to order a 10" Wolfbox and make whatever mods are needed to fit it to the standard mirror leg and hide the cables as best as I can but try and make the end result as slick as possible. I will also mod the visors and have them re trimmed. Will post my progress. Thumbs Up Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #1058092 21st Jan 2025 7:01am
jst
i think 10" is sounding better option over the 12 with visors etc. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1058150 21st Jan 2025 6:07pm
BuckBlu110
Here we go. I’ve fixed the camera to the bottom of the brake light on the inside of the rear door. So the view is essentially of what you would see out the back.
Post #1058727 27th Jan 2025 3:54pm
BuckBlu110
I’ve got an aftermarket brake light but the principle of the placement is the same as if I had a factory light.
And the sun visors. I may do the same as Andy at some point and cut another pair of visors to the right shape as I quite like where the mirror is, much higher, leaving more of the screen visible.
Post #1058730 27th Jan 2025 4:30pm
mcma1
Post #1058762 27th Jan 2025 10:18pm
BuckBlu110
I put it on the dash, just above the center screw by the windscreen, I haven’t stuck it down yet as I wanted to try it there for a bit to make sure it works correctly.
It’s barely visible from my driving position.
The other place I was going to put it was stuck to the windscreen behind the mirror so it wasn’t visible to the driver.
Post #1058763 27th Jan 2025 10:30pm
jst
I have gone for the 10" jansite one, £59. Not 4k but only want rear view which most seemed to be lower res rear anyway. Looking to fit to the 130 this am. Camera looks same as one shown above.
Probably fit camera to the rack I think,.Will see if I get enough downward angle as would like hitch showing if scrolled down. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1058775 28th Jan 2025 6:57am
