Home > In Car Electronics > Wolfbox rear Camera
Page 2 of 2 <12
jst
I have gone for the 10" jansite one, £59. Not 4k but only want rear view which most seemed to be lower res rear anyway. Looking to fit to the 130 this am. Camera looks same as one shown above.
Probably fit camera to the rack I think,.Will see if I get enough downward angle as would like hitch showing if scrolled down. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1058776 28th Jan 2025 7:57am
Gremlin110
I have a G930 from Wolfbox in my Puma 100. It's only been installed for a few days so i am still getting used to it. i've fiddled with some settings, but so far i am pretty impressed. I've installed my camera above my rear washer jet, and so far, apart from a hole that is currently letting in the rain (goop didnt arrive on the day expected and grommets are not big and also small enough) fitting it was pretty much a breeze - the ONLY complaint my mate had installing the hard wire bit of it was working out something to do with the fuses (i was, absolutely useless with the electricery stuff). I'll nab some photo's of what it's like when it's daylight and not raining Wink
Post #1058812 28th Jan 2025 6:50pm
Les Brock
I have a Jansite one, does everything I need it to:
Front, rear cam
Front, rear or split screen Regards
Les
Def 90 M57
Post #1058815 28th Jan 2025 7:16pm
HuddyM
United Kingdom 2009 Defender 90 Puma 2.4 CSW Stornoway Grey
I got the Wolfbox G900 Pro, had it for about two weeks before getting an auto electrician out to hard wire it in.
Thanks to my tracker, I’m able to keep an eye on the battery levels. Even with the parking mode on it’s barely touching the battery.
The on screen icons can be a bit glaring at night time, but I hear a firmware update is on its way to adjust that. I mounted mine above the washer jet housing. I extended the hole used by the water pipe to save additional drilling into the landy. I used the included sticky pad to attach to the car, and despite numerous journeys and the fact it’s rained since Xmas day (feels that way) it’s still stuck on.
I’m yet to get confident enough to trust the parking lines on the reverse display, but the quality of the videos are fantastic.
I’m a little disappointed by the fouling of the sun visors, I’m weighing up cutting them down and recovering them, or moving the rearview screen.
Post #1058836 28th Jan 2025 9:26pm
ThreePointFive
United Kingdom 1988 Defender 90 V8 Petrol HT Bonatti Grey
I'll be grateful for a look, I need to do something with mine. One life - get one.
Post #1060054 9th Feb 2025 6:36pm
jst
when we do that wiring then! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1060144 10th Feb 2025 7:03pm
Page 2 of 2 <12
