Home > Td5 > 15P Fuel Pressure Regulator Pipe (Into Head)
CJs110
Canada 2003 Defender 110 Td5 SW Zambezi Silver
Hi All,
Had a fuel leak which I confirmed is a pinhole in the rubber hose with metal ends that runs from the Fuel Pressure Regulator into the head (3 pipe version, 15P engine)
I thought it would be a straight forward replacement (had to order a whole FPR unit, couldn't find the pipe separate) but I can't figure out how to approach removing the connection towards the front of the head, there seems to be no clearance to get the pipe off (highlighted in red)
Has anyone replaced this pipe before? If so how? Do I have to remove the entire intake assembly Big Cry
It's currently -8c out so I was hoping it would be straightforward and could just do on the driveway but I guess I gotta get into the garage Laughing
Post #1058513 24th Jan 2025 10:39pm
CJs110
Update: Definetely need to remove the Intake/Inlet manifold
Ok probably should have done my research before posting, looking around the internet looks like no tool will really reach that
So off the inlet manifold must come Crying or Very sad
Just ordered a gasket, once that comes in guess I'll get cracking
Post #1058514 24th Jan 2025 11:07pm
landy andy
I swapped mine out last year. Just used an open end of a spanner only get the smallest part of a turn, but enough that it worked without taking anything off.
Post #1058516 24th Jan 2025 11:34pm
CJs110
I've got atleast till next weekend before that gasket comes in, so I'll try and get it in the garage and try again with a spanner - maybe from underneath? When I just tried earlier I kept contacting the manifold runners or the head casting itself.
Post #1058517 24th Jan 2025 11:39pm
landy andy
I had swapped my FPR about 18 months/2 years before and had not used the new along the engine pipe. So when mine started to leak at the joint of hose to solid pipe I had it in stock. I managed from above just with open ended spanner. Maybe try a different spanner as head angle maybe different on it.
I, like you, thought I was in for a big job, but ended up being a breeze of a job.
Post #1058521 25th Jan 2025 12:22am
Ashbyandy
England 2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
A mechanic at my local indi, used a grinder and cut an old spanner down on each side, making it very narrow, which then made it easier to get to. You could just buy a cheap open ended spanner, and try it 👍. Hope you can manage it without removing the manifold, saves the risk of breaking any studs, which would be a pain to fix,
Ashby Andy
Post #1058531 25th Jan 2025 9:54am
CJs110
Found a spare spanner and used a grinder to thin it out, but still wasn't able to quite get it. I figured I need to remove the alternator support bracket and in undoing the bottom bolt I may have made my situation worse as now I see wetness around the Alternator Oil Feed (likely when loosening the bottom bracket bolt I put too much pressure?) Rolling Eyes
Might have to order YKL100120 now too.....
If I have some more time I may modify the spanner more to try and get in, but it feels like the closest inlet manifold stud/nut prevents me from really reaching the fuel pipe. But at this point inlet gasket ordered so I'm preparing myself to go down that avenue.
Post #1058591 25th Jan 2025 7:09pm
