Home > Td5 > 15P Fuel Pressure Regulator Pipe (Into Head) |
CJs110 Member Since: 06 Sep 2023 Location: Windsor Posts: 20 |
Ok probably should have done my research before posting, looking around the internet looks like no tool will really reach that
So off the inlet manifold must come Just ordered a gasket, once that comes in guess I'll get cracking |
24th Jan 2025 11:07pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5788 |
I swapped mine out last year. Just used an open end of a spanner only get the smallest part of a turn, but enough that it worked without taking anything off.
24th Jan 2025 11:34pm |
I've got atleast till next weekend before that gasket comes in, so I'll try and get it in the garage and try again with a spanner - maybe from underneath? When I just tried earlier I kept contacting the manifold runners or the head casting itself.
24th Jan 2025 11:39pm |
I had swapped my FPR about 18 months/2 years before and had not used the new along the engine pipe. So when mine started to leak at the joint of hose to solid pipe I had it in stock. I managed from above just with open ended spanner. Maybe try a different spanner as head angle maybe different on it.
I, like you, thought I was in for a big job, but ended up being a breeze of a job. |
25th Jan 2025 12:22am |
Ashbyandy Member Since: 17 Dec 2015 Location: Leicestershire Posts: 224 |
A mechanic at my local indi, used a grinder and cut an old spanner down on each side, making it very narrow, which then made it easier to get to. You could just buy a cheap open ended spanner, and try it 👍. Hope you can manage it without removing the manifold, saves the risk of breaking any studs, which would be a pain to fix,
Ashby Andy |
25th Jan 2025 9:54am |
Found a spare spanner and used a grinder to thin it out, but still wasn't able to quite get it. I figured I need to remove the alternator support bracket and in undoing the bottom bolt I may have made my situation worse as now I see wetness around the Alternator Oil Feed (likely when loosening the bottom bracket bolt I put too much pressure?)
Click image to enlarge Might have to order YKL100120 now too..... If I have some more time I may modify the spanner more to try and get in, but it feels like the closest inlet manifold stud/nut prevents me from really reaching the fuel pipe. But at this point inlet gasket ordered so I'm preparing myself to go down that avenue. |
25th Jan 2025 7:09pm |
