Home > My Defender > Galway Green, 2011 Defender 110 Station Wagon |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
I hope you're aware of the "Defender wave"!!! James
14th Oct 2019 8:56pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5213 |
sadly not, but it does give you a choice of a better looking wheel. I have one on mine that looks look, Not racing car looking either. One of those things we have to give up to keep these safe sadly. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
15th Oct 2019 4:56am |
Stebo Member Since: 04 Oct 2019 Location: Northern Ireland Posts: 32 |
Happy to report my wife is loving the first couple of weeks of Defender ownership.
I had it out earning it's keep last nigh, towing a trailer full of horse manure about 10 miles out the road. I was a bit concerned that it wouldn't tow as well as my wife's old XC90 but it did the job well. The brakes mightn't just inspire as much confidence, but it did everything I asked of it. Click image to enlarge Click image to enlarge I'm not as used to judging the tow-bar on this car, (and the defender doesn't have a soft plastic bumper!) so I reckon that a reversing camera and some work lights for hitching up would go a long way to making life a bit easier. Did some Friday night shopping and bought a Scenelite S17 and a JVC KD-X561DBT plus a cheapy camera to see where and what works well (I'll likely replace this with a decent camera when I've figured out what I actually want). I didn't want to go double din so I hope that the 3" screen is good enough, and also that the blue colours doesn't do my head in against the LR green https://uk.jvc.com/car-entertainment/bluetooth/KD-X561DBT/ https://www.amazon.co.uk/gp/product/B00RVP...&psc=1 https://www.amazon.co.uk/gp/product/B07RJQ...&psc=1 https://www.labcraft.co.uk/product/scenelite-si7/ |
25th Oct 2019 11:52pm |
I spent Saturday fitting the above, and have nearly got everything sorted. My only issue is the wiring of the Scenelite, which I intended to operate off this switch - https://www.mudstuff.co.uk/genuine-style-t...rwork.html (not connected to reverse or anything). The switch appears to be designed for running a relay, but I presume with a LED light such as the S17 this wouldn't be required? The following wiring diagram was supplied with the switch:
Click image to enlarge Ideally I would want this switch to operate as follows: - illuminated green along with the rest of the dash - amber dot illuminated when scenelite is turned on - can turn on scenelite even if the ignition is off - not using a relay (unless the advice is that I should use one) Can anybody advise if this would work if I run a live from the battery into terminal 1, a splice from another switch in to terminal 2, negative from battery to terminal 3/4, and live to scenelite from terminal 5, and then negative from scenelite back to battery neg (based on the terminal numbers in the image)? I also presume that instead of wiring neg back to the battery I could also just "ground" it against an appropriate chassis connection? Is there anybody more electrically minded than me that could advise on if that will set my car on fire (or if there is an easier way)? The new head-unit and reversing cam are a great job, but now that I know it works I might invest in a better camera. The cheap one I bought has pointless guidance lines that aren't right and flashes a message like "use your eyes" at the top, which is the most important bit of the image. I would also go a slightly wider angle. I have managed to mount it at the back door so I can just see the tow-ball, but also get a good view for parking / avoiding small children - I will get some photos and put them up here when I get a chance |
4th Nov 2019 1:39pm |
If you connect 12v directly to terminal 1 then pressing the switch will create a dead short and bad things will happen.
The connection to terminal 5 is an incoming 12v to power the amber LED and won't work the other way around in the way that you suggest. Whilst the current draw of your Scenelight doesn't warrant the use of a relay, the switch is designed to switch an earth rather than 12v and so it's far easier to wire as shown in the diagram. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
4th Nov 2019 10:08pm |
Aw, yes, see what you mean. I’ll just grab a relay in that case. Thanks for the advice
4th Nov 2019 11:01pm |
Here's a few photos of my scenelite. Hard to capture just how bright this is at night. More than adequate anyway!
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Trying to capture how it lights up a pitch black yard - camera kinda darkens though, so it’s not a great example Click image to enlarge Here is a photo of the drivers mirror, with just the stock reversing light, and then with the scenelite Click image to enlarge Click image to enlarge Last edited by Stebo on 16th Nov 2019 11:50pm. Edited 1 time in total |
16th Nov 2019 4:15pm |
And the JVC headunit and reversing cam
Click image to enlarge Click image to enlarge Click image to enlarge |
16th Nov 2019 4:16pm |
Apart from a few electrical gremlins and replacing the standard clutch with a LOF extreme spec clutch-kit, the Defender has been pretty faultless, until at 92,000 miles it failed it's mot for the first time...... EGR valve brought the engine management light on
New EGR ordered, knuckles predictably skinned, EGR replaced and fault-codes reset. Hopefully that will be it sorted again. I just thought I'd post to flag up this link - https://www.landrovermonthly.co.uk/article...gr-valve/. I found this a great bit of info when doing the EGR valve. |
16th Jan 2025 5:56pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10830 |
Great you still have the 110 and thank you for the update Clayton.
16th Jan 2025 9:11pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2223 |
Go green or go home 💚 |
17th Jan 2025 5:18pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
welcome great year and great colour, check the recalls have been done especially the front axle brackets , LR will still do them FOC if not already done DEFENDER 90 TDCI XS,
18th Jan 2025 1:41pm |
