Home > My Defender > Galway Green, 2011 Defender 110 Station Wagon
Page 2 of 2 <12
JOW240725
I hope you're aware of the "Defender wave"!!! James
Instagram @suffolk_rovers
Post #798211 14th Oct 2019 8:56pm
Stebo
Northern Ireland 2011 Defender 110 Puma 2.4 XS CSW Galway Green
I wasn't, but after the first 100 or so miles I ( and surprisingly also my wife) am now a fully paid up member of the defender-wave club. Very Happy
Post #798221 14th Oct 2019 9:57pm
Procta
Stebo wrote:
Thanks for the comments. Yes security is top of the list, but I just need to figure out what would work best for our circumstances. I'll do a bit of research, but I kinda like the standard steering wheel, so not sure if a wheel-lock or removable boss will work with standard wheel.
I spoke to Belfast Land Rover Centre (BLRC) about getting anti-corrosion treatment done but they have a 1 year+ waiting list apparently. Thanks for the heads-up on DF Engineering - looks like he knows what he's at, I'll give him a call tomorrow.
sadly not, but it does give you a choice of a better looking wheel. I have one on mine that looks look, Not racing car looking either. One of those things we have to give up to keep these safe sadly. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #798226 15th Oct 2019 4:56am
Stebo
Happy to report my wife is loving the first couple of weeks of Defender ownership.
I had it out earning it's keep last nigh, towing a trailer full of horse manure about 10 miles out the road. I was a bit concerned that it wouldn't tow as well as my wife's old XC90 but it did the job well. The brakes mightn't just inspire as much confidence, but it did everything I asked of it.
I'm not as used to judging the tow-bar on this car, (and the defender doesn't have a soft plastic bumper!) so I reckon that a reversing camera and some work lights for hitching up would go a long way to making life a bit easier.
Did some Friday night shopping and bought a Scenelite S17 and a JVC KD-X561DBT plus a cheapy camera to see where and what works well (I'll likely replace this with a decent camera when I've figured out what I actually want). I didn't want to go double din so I hope that the 3" screen is good enough, and also that the blue colours doesn't do my head in against the LR green
https://uk.jvc.com/car-entertainment/bluetooth/KD-X561DBT/
https://www.amazon.co.uk/gp/product/B00RVP...&psc=1
https://www.amazon.co.uk/gp/product/B07RJQ...&psc=1
https://www.labcraft.co.uk/product/scenelite-si7/
Post #799568 25th Oct 2019 11:52pm
Stebo
I spent Saturday fitting the above, and have nearly got everything sorted. My only issue is the wiring of the Scenelite, which I intended to operate off this switch - https://www.mudstuff.co.uk/genuine-style-t...rwork.html (not connected to reverse or anything). The switch appears to be designed for running a relay, but I presume with a LED light such as the S17 this wouldn't be required? The following wiring diagram was supplied with the switch:
Ideally I would want this switch to operate as follows:
- illuminated green along with the rest of the dash
- amber dot illuminated when scenelite is turned on
- can turn on scenelite even if the ignition is off
- not using a relay (unless the advice is that I should use one)
Can anybody advise if this would work if I run a live from the battery into terminal 1, a splice from another switch in to terminal 2, negative from battery to terminal 3/4, and live to scenelite from terminal 5, and then negative from scenelite back to battery neg (based on the terminal numbers in the image)? I also presume that instead of wiring neg back to the battery I could also just "ground" it against an appropriate chassis connection?
Is there anybody more electrically minded than me that could advise on if that will set my car on fire (or if there is an easier way)?
The new head-unit and reversing cam are a great job, but now that I know it works I might invest in a better camera. The cheap one I bought has pointless guidance lines that aren't right and flashes a message like "use your eyes" at the top, which is the most important bit of the image. I would also go a slightly wider angle.
I have managed to mount it at the back door so I can just see the tow-ball, but also get a good view for parking / avoiding small children - I will get some photos and put them up here when I get a chance
Post #800740 4th Nov 2019 1:39pm
If you connect 12v directly to terminal 1 then pressing the switch will create a dead short and bad things will happen.
The connection to terminal 5 is an incoming 12v to power the amber LED and won't work the other way around in the way that you suggest.
Whilst the current draw of your Scenelight doesn't warrant the use of a relay, the switch is designed to switch an earth rather than 12v and so it's far easier to wire as shown in the diagram. Darren
Post #800827 4th Nov 2019 10:08pm
Stebo
Aw, yes, see what you mean. I’ll just grab a relay in that case. Thanks for the advice
Post #800834 4th Nov 2019 11:01pm
Stebo
Here's a few photos of my scenelite. Hard to capture just how bright this is at night. More than adequate anyway!
Trying to capture how it lights up a pitch black yard - camera kinda darkens though, so it’s not a great example
Here is a photo of the drivers mirror, with just the stock reversing light, and then with the scenelite
Post #802460 16th Nov 2019 4:15pm
Stebo
And the JVC headunit and reversing cam
Post #802461 16th Nov 2019 4:16pm
Stebo
Apart from a few electrical gremlins and replacing the standard clutch with a LOF extreme spec clutch-kit, the Defender has been pretty faultless, until at 92,000 miles it failed it's mot for the first time...... EGR valve brought the engine management light on Crying or Very sad
New EGR ordered, knuckles predictably skinned, EGR replaced and fault-codes reset. Hopefully that will be it sorted again.
I just thought I'd post to flag up this link - https://www.landrovermonthly.co.uk/article...gr-valve/. I found this a great bit of info when doing the EGR valve.
Post #1057574 16th Jan 2025 5:56pm
L110CDL
Great you still have the 110 and thank you for the update Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #1057600 16th Jan 2025 9:11pm
keith
Mike c wrote:
Very nice Defender and colour, a tdci xs 110 is pure luxury compared to earlier models! Thumbs Up
Go green or go home 💚
Post #1057677 17th Jan 2025 5:18pm
Page 2 of 2 <12
