Home > Td5 > Original LR thermostat sux - disappointing
TexasRover
So about 6 months ago I fitted a brand new LR thermostat GBP 60 in my Defender Td5 and ever since it barely manages to get the needle to get out of the blue. Had to drive it hard to get it to about 1/4 and even then it would drop back in the blue on idle.
Annoyed me enough to go and replace it, but with what? What could possibly be better than an original Land Rover part?
Oh hang on, a GBP 30 "OEM" (made in China) thermostat is what you need. Black, if you blow on the bigger pipe (steady on..) it passes no air, while on the Original Land Rover pos plenty of air passes. Fitted OEM and yes heating restored, needle in the middle-ish
Given the number of Landrovers that use this thermostat, you would think they have the quality under control. There goes another myth.
https://rimmerbros.com/Item--i-PEM101021P
Post #1057662 17th Jan 2025 2:01pm
Martin
Site Admin
That's a K series thermostat?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1057664 17th Jan 2025 2:25pm
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
You should always test new thermostats in a pan of warm water before fitting i have recently had a couple of genuine LR ones fail and i am now on a OEM on the 110 that gets up to temperature and stays there even during the cold 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1057672 17th Jan 2025 4:36pm
TexasRover
Sorry you are right I gave the wrong link. I bought PEM100990P. 87 deg
Also available for $9 on Alibaba... Parts nowadays is hit and miss. I tested this one and it is working well, hopefully for years to come
Post #1057678 17th Jan 2025 5:19pm
Mo Murphy
I've had genuine and Waxstat OEM fail to operate properly straight out of the packet. I always test replacements now in a pan of water.
50 Shades of Pennine Grey
Post #1057693 17th Jan 2025 7:56pm
NickMc
Likewise had a few brand new ones out of the packet not work too.
Post #1057715 17th Jan 2025 11:25pm
