Home > General & Technical (L663) > Question: L663 Heated steering wheel function retrofit |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2888 |
Yes you can retrofit the heated steering wheel, l've seen it advertised online.
LR Retrofits do it. |
31st Oct 2023 8:02pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1421 |
You will need a heated steering wheel, switch pack and harness and I believe you need the whole of the indicator/wiper switch assembly as the clock spring doesn't come separate on the Defender and a new one is needed for the heated steering wheel. I have terrible problems with arthritis in my hands and changed the heated leather steering wheel on mine to an heated alcantara one (along with the paddles) and it feels so much better. Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
31st Oct 2023 11:44pm |
captain slow Member Since: 22 Jun 2011 Location: Herts Posts: 356 |
Thanks Ian.
That sounds like a possibility. Any help you can give on where to source the parts (particularly the alcantara wheel) would be greatly appreciated Many thanks John 2.2 Tdci 110 XS CSW Corris Grey Prince Harry's D3 (gone but not forgotten) 300 Tdi 110 CSW (gone but not forgotten) |
1st Nov 2023 4:47pm |
Hi John, I got all my bits from Sophie at Duckworth Land Rover (forum sponsor) as I wanted all Land Rover genuine bits. I did all the work myself but as I already had the heated wheel I didn't need to replace the clockspring also there is a setting in the CCF file which needs changing to enable the heated wheel Cheers Ian
1st Nov 2023 11:34pm |
makd110 Member Since: 21 Mar 2024 Location: Sussex Posts: 2 |
Hi All
My first post on the forum, but have followed for quite some time; a great resource. I've got a 2020 110SE and decided to add a heated steering wheel. I have installed the necessary compatible column stalks/switch unit, heated steering wheel, right hand wheel switch and wiring harness. Also installed a 10A fuse in socket no43 and used my GAP Diagnostics to modify the CCF for a heated steering wheel. Despite all of the above, I keep getting the fault 'B1380-16 (2F) Steering Wheel Right Switch Pack - circuit voltage below threshold (this is the GWM-Gateway Module 'A' ECU) and of course no heating of the wheel itself! I can only assume that the right switch has a fault, despite it seemingly working, but thought I would check I haven't missed any other key step. Many thanks Mark |
21st Mar 2024 4:17pm |
The only thing I can think of is are you sure you plugged all the wires from the new harness in properly? I take it you have replaced the harness with the black plastic cage on it? I know when I did mine there was one connection that was really tricky but that may have been for the flappy paddles as I fitted them when I was doing the wheel. Cheers Ian
21st Mar 2024 6:17pm |
Thanks Hairy Dan for the reply - I did in fact remove the wheel and strip it down again to double check - all is correct and cannot see any damage to the harness or switch unit. I am certain I also correctly hooked up the clock spring/stalk unit - unless there is a hidden plug I am not aware of!
As you can imagine, I don't really want to buy new units to fault find, but not sure what else to try other than replace the right hand switch pack on the steering wheel. Many thanks Mark |
22nd Mar 2024 1:15pm |
mshale Member Since: 13 Jan 2025 Location: USA Posts: 2 |
Mark,
Did you ever figure out what your issue was? I’d like to retrofit the heated wheel to my ‘21. I have done a fair amount of research and part number lookups. I have not found a guide on doing any of this work and thus do not know what to change in the CCF. I have a GAP tool, though I have not yet used it on the Defender. In my research I’ve found that there are two steering wheel part numbers for a leather heated wheel. One is before a certain VIN, and the other is after. I wonder if that has anything to do with your issues? And I wonder if it matters at all. Strange that there are two part numbers of it doesn’t matter. Anyway, the part numbers I found are: LR132112 For the older one LR183010 For the newer one. I would like to create a guide for this if I can get it done successfully. |
13th Jan 2025 1:27am |
Sadly Mark has not been back since his post last Summer, so we may never know. l hope he got it working after spending so much on parts.
13th Jan 2025 9:32am |
Well that’s a shame!
I know that the retrofit has been done, but no one has posted what to change in the CCF. The hardware is available, but the tricky bit is in the code. All of the modifiers I seem to find online are in the UK and will not assist. I asked one of them and they said I would have to ship my Defender to them! |
17th Jan 2025 2:02am |
Colin68 Member Since: 18 Jul 2024 Location: Blackpool Posts: 84 |
Have you not compared your CCF files to a vehicle which has this fitted?
You could try this? EUCD-171 Heated Steering Wheel With Heated Steering Wheel |
17th Jan 2025 7:01am |
