Home > General & Technical (L663) > Question: L663 Heated steering wheel function retrofit
captain slow
United Kingdom 2014 Defender 110 Puma 2.2 CSW Corris Grey
Hi All,
I am seeking the advice of the collective:
I am looking at buying a second hand L663, but it doesn't have a heated steering wheel (which is a must for my wife who suffers with Raynaud's disease).
Does anyone know if it something that can be added later either by enabling or swapping the steering wheel out for one that does? Is the wiring in place? etc
thanks in advance 2.2 Tdci 110 XS CSW Corris Grey
Prince Harry's D3 (gone but not forgotten)
300 Tdi 110 CSW (gone but not forgotten)
Post #1013417 31st Oct 2023 8:23pm
lightning
Yes you can retrofit the heated steering wheel, l've seen it advertised online.
LR Retrofits do it.
Post #1013425 31st Oct 2023 9:02pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
You will need a heated steering wheel, switch pack and harness and I believe you need the whole of the indicator/wiper switch assembly as the clock spring doesn't come separate on the Defender and a new one is needed for the heated steering wheel. I have terrible problems with arthritis in my hands and changed the heated leather steering wheel on mine to an heated alcantara one (along with the paddles) and it feels so much better. Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1013443 1st Nov 2023 12:44am
captain slow
Thanks Ian.
That sounds like a possibility. Any help you can give on where to source the parts (particularly the alcantara wheel) would be greatly appreciated Thumbs Up
Many thanks
John 2.2 Tdci 110 XS CSW Corris Grey
Post #1013547 1st Nov 2023 5:47pm
Hairy Dan
Hi John, I got all my bits from Sophie at Duckworth Land Rover (forum sponsor) as I wanted all Land Rover genuine bits. I did all the work myself but as I already had the heated wheel I didn't need to replace the clockspring also there is a setting in the CCF file which needs changing to enable the heated wheel Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1013598 2nd Nov 2023 12:34am
makd110
Prolbem with retro-fit heated wheel
Hi All
My first post on the forum, but have followed for quite some time; a great resource.
I've got a 2020 110SE and decided to add a heated steering wheel. I have installed the necessary compatible column stalks/switch unit, heated steering wheel, right hand wheel switch and wiring harness. Also installed a 10A fuse in socket no43 and used my GAP Diagnostics to modify the CCF for a heated steering wheel.
Despite all of the above, I keep getting the fault 'B1380-16 (2F) Steering Wheel Right Switch Pack - circuit voltage below threshold (this is the GWM-Gateway Module 'A' ECU) and of course no heating of the wheel itself!
I can only assume that the right switch has a fault, despite it seemingly working, but thought I would check I haven't missed any other key step.
Many thanks
Mark
Post #1028868 21st Mar 2024 5:17pm
Hairy Dan
The only thing I can think of is are you sure you plugged all the wires from the new harness in properly? I take it you have replaced the harness with the black plastic cage on it? I know when I did mine there was one connection that was really tricky but that may have been for the flappy paddles as I fitted them when I was doing the wheel. Cheers Ian
Kielder 4x4 Safari
Post #1028887 21st Mar 2024 7:17pm
makd110
Thanks Hairy Dan for the reply - I did in fact remove the wheel and strip it down again to double check - all is correct and cannot see any damage to the harness or switch unit. I am certain I also correctly hooked up the clock spring/stalk unit - unless there is a hidden plug I am not aware of!
As you can imagine, I don't really want to buy new units to fault find, but not sure what else to try other than replace the right hand switch pack on the steering wheel.
Many thanks
Mark
Post #1028978 22nd Mar 2024 2:15pm
mshale
Mark,
Did you ever figure out what your issue was? I’d like to retrofit the heated wheel to my ‘21. I have done a fair amount of research and part number lookups. I have not found a guide on doing any of this work and thus do not know what to change in the CCF. I have a GAP tool, though I have not yet used it on the Defender.
In my research I’ve found that there are two steering wheel part numbers for a leather heated wheel. One is before a certain VIN, and the other is after. I wonder if that has anything to do with your issues? And I wonder if it matters at all. Strange that there are two part numbers of it doesn’t matter. Anyway, the part numbers I found are:
LR132112 For the older one
LR183010 For the newer one.
I would like to create a guide for this if I can get it done successfully.
Post #1057213 13th Jan 2025 2:27am
lightning
Sadly Mark has not been back since his post last Summer, so we may never know. l hope he got it working after spending so much on parts.
Post #1057227 13th Jan 2025 10:32am
mshale
Well that’s a shame!
I know that the retrofit has been done, but no one has posted what to change in the CCF. The hardware is available, but the tricky bit is in the code.
All of the modifiers I seem to find online are in the UK and will not assist. I asked one of them and they said I would have to ship my Defender to them!
Post #1057619 17th Jan 2025 3:02am
Colin68
Have you not compared your CCF files to a vehicle which has this fitted?
You could try this?
EUCD-171 Heated Steering Wheel
With Heated Steering Wheel
Post #1057623 17th Jan 2025 8:01am
mshale
As luck would have it, I got a call from my dealer this morning and they were able to work me in for service and provided me a loaner. It’s a 2024 S, but it has a heated steering wheel and windscreen.
My GAP tool is locked to my VIN, so I’m not sure I’ll be able to see the CCF without contacting them first.
Post #1057683 17th Jan 2025 7:05pm
makd110
Hello All
Apologies for the delayed response, I didn't pick up the various messages. Unfortunately I have not resolved my installation - the latest is that my diagnostic keeps telling me that the steering wheel right switch pack has a fault.
I am somewhat reluctant to spend a lot more on buying a replacement unit to only find that it is not that which is the issue. I am able to manage without a warm wheel at the moment.
Post #1064202 29th Mar 2025 4:50pm
