![]() | Home > Maintenance & Modifications > Axle and gear box oils |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20718 ![]() ![]() |
Axles and transfer box are fill to filler level, gearbox is 2.2L precisely.
If you are looking for quantity to purchase you can look here: https://www.castrol.com/en_gb/united-kingd...inder.html You’ll need up to 2L per axle, and 3L for the transfer box. Both of these are less, but you’ll need to buy these sizes. Gearbox is GL4 only, Axle and transfer box the same, but GL5. The gearbox oil must be filled the precise amount with GL4, and you’ll need 1L fluid transfer pump to get it in there, a manual one for £20 will do. Personally I use Castrol now, but you can use others all personal choice of course. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
