Home > Tdi > Transmission noise
SADS
United Kingdom 1990 Defender 90 200 Tdi SW Arles Blue
Transmission noise
Hi everyone,
Slowly making improvements to my 200tdi.
I have a loud rumbling vibration / noise between roughly 40-50mph. I replaced both front and rear propshafts/UJ’s for brand new. I did think the noise/vibration had gone but now it seems to have returned.
Could it be the new props/UJ’s already have an issue, or could it be something else? What should i check next?
Thanks for anyones time to respond.
Post #1056961 10th Jan 2025 8:01pm
Dukeofastley
Hi ,
Have you checked all the mounts ( engine and gearbox )? I had a similar issue on a rumbling noise which I traced to a gearbox mount which had split.
Worth checking ..
Cheers,
Andrew.
Post #1057043 11th Jan 2025 4:10pm
landy andy
If you are considering that it maybe a prop then put a couple of pumps of grease in each grease nipple and see if that alters/removes the noise.
Assume you checked wheel bearings.
I’d also drop the oils out of the boxes and diffs and check what comes out.
Post #1057045 11th Jan 2025 4:14pm
Re-grease the UJ’s see what happens, if it’s a bit better or a slight change then that’ll give you a clue, it could be also unbalance due to uneven greasing, or out of phase.
Did you put everything back exactly as it was, or fit brand new prop(s)? TheThunderRolls🇬🇧🇺🇸
Post #1057052 11th Jan 2025 4:53pm
SADS
Thanks for the replies.
Brand new props which had been greased. Perhaps i should pump more in as suggested, i will give that a go
I haven’t checked wheel bearings, no. I did think it could be the bearings, but i was waiting to see if someone also thought this could be that.
Engine was rebuilt in November so the mounts should be good.
Gearbox, transfer box and Diffs all oils replaced just before christmas.
Post #1057081 11th Jan 2025 7:54pm
mini Anaconda
I had similar on my 200tdi, it was the engine mount. BORG - Bucks & Oxon 4x4 Response Group
Post #1057104 12th Jan 2025 12:33am
donmacn
A bit "left field" perhaps, but easy enough to check for: have a look to see that the radius arms are properly attached onto the front axle, and the trailing arms to the rear.
I had a situation where I was getting a speed-related noise which I was struggling to track down. My initial thoughts were all the same as yours - props, handbrake, A frame, bearings. Then almost by chance I noticed that on the driver's radius arm, the rear most bolt was entirely missing. The car had passed an MOT the week before I noticed.... Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1057117 12th Jan 2025 10:23am
SADS
What about the engine mounts exactly, cracked? Not genuine part?
Post #1057122 12th Jan 2025 10:31am
SADS
I will get under the vehicle ASAP and check this.
Maybe separate, maybe not, but when driving through the gears, if i move into a gear slightly sooner than ideal (say into 5th, but then I cant accelerate because of a slow car in front, for example) and then i get a strange ringing noise.. when continuing to accelerate to find more revs. From what sounds like the accelerator pedal area within the engine bay / under the vehicle. Pretty vague description i know, but i dont suppose anyone gets what i mean do you, and what it is?
Also maybe related to the rumbling, maybe not. I had the engine rebuilt 1,700 miles ago. Currently running the engine in. When driving normally, i sometimes get a wiff of burning rubber. Oil levels all spot on, coolant levels kept topped up. I did have a split plug gasket on the radiator which was spraying the engine bay with coolant, but that was sorted quickly and the coolant was kept topped up the whole time.
Engine is running nicely, not strange noises. Temp gauge takes a while to get up to temp but once it is, sits there without any play.
Any idea?
Post #1057486 15th Jan 2025 7:58pm
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
Some other vibration, jangly noises (if not UJs):
Exhaust loose
Brake pads not having anti vibration clips
X-eng disc handbrake pads failing LR Workshop
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #1057489 15th Jan 2025 8:21pm
SADS
Not exhaust i dont think, as i have just ensured this isnt touching anything underneath and added new rubbers.
Got drums brakes all round.
Hand brake pads.. not sure, would i need to remove the outer casing to check? Would this be checked on a MOT? Passed in Nov
Post #1057494 15th Jan 2025 9:22pm
Will@LRW
Only if you have a disc handbrake, which is an aftermarket mod LR Workshop
Post #1057503 15th Jan 2025 11:27pm
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
Simple one….. Have you checked your tyres? I had uneven wear on the front inside edge, due to a slightly bent track rod it had caused the inside tread on both front tyres to be quite castellated. Created a real rumble at 40-50 mph. Worth a quick check maybe 👍
Post #1057615 16th Jan 2025 11:13pm
Les Brock
Propshafts may need Phasing if not already done ?
This is normally vibration around 50 on overrun
Post #1057632 17th Jan 2025 9:39am
SADS
Ah yeah i looked up the handbreak Mod, looks great but unfortunately i do not have this, would a dr handbrake rattle / ring at all?
Tyres were new less than 10k miles ago, same rumble with old set too.
Propshaft - ah, whats the correct way to phase the UJ’s? Would it be that the UJs arent phased when buying a full prop with both UJ’s, Greased?
Post #1057636 17th Jan 2025 10:42am
