![]() | Home > My New Defender (L663) > insuring new D350 X difficulties - what cat immobiliser? |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2660 ![]() ![]() ![]() |
My wife has a Velar and in her incontrol account click on SECURE TRACKER, under THATCHAM click on view certificate.
It then shows the Certificate of Installation document. This is personalised to the owner and vehicle so I won’t copy and paste it here. The part I will share is System model Land Rover : Secure Tracker Security Serial Number 106VIKEB05213 THATCHAM Evaluation No : Cat 6 TTS -1101/0913 SOC Ref No : JLR/F/6778 This of cause can be sent to the Insurance company. I would have thought that the dealer could get this for you I hope that this helps you. Regards PS, it’s a 22 model |
deaallen Member Since: 15 Feb 2016 Location: Basingstoke Posts: 266 ![]() ![]() ![]() |
Thanks Mark,
That helps a lot, I think the people I'm speaking with at the nfu are getting things slightly confused and as the dealers aren't sure what they want either. I'll have a word with the dealers and see if they're able to get me that specific info for this car to send over to the nfu. Thanks! |
Oswiperus Member Since: 12 Aug 2020 Location: Chelmsford Posts: 52 ![]() ![]() |
I believe a D350 should be a MY25, Secure Tracker Pro became standard for MY25 rather than an option over the standard Secure Tracker.
Secure Tracker Pro is Thatcham S5 which is the current the highest level of protection. Cat 1 & Cat2 have been replaced with S5 & S7. Check with the dealers to find out if it's a MY25, they should at least be able to tell you that. 110 D250 S Hardtop Tasman Blue |
