Home > Technical > Puma 2.2 Door Locks Etc
Dorothy
This morning I popped the old girl on. Lumpy start due to Glowplugs 1 and 3 not working. I digress... I whacked the heater on, started de-icing (outside ice first). Didn't get around to the interior ice because the the driver's door button to regain entry, locked all the doors.
Oopsy.
Went off to do the rounds leaving the running, locked Landy. Big Cry
Returned to attempt a break-in. As you do... (No spare).
Gained entry. Less said the better.
I really need to replace the lock barrel(s) and need a spare and probably a coded spare fob too.
Naturally I have oodles of additional security features as it has been known that some locks can be quite 'flexible' with which keys they allow.
Of course the alarm would sound but I am wondering what is required to ensure cold/damp doesn't cause this locking issue again. 2001 Defender Special Vehicles TD5 Hardtop (Ex Scottish & Southern) Side Lockers, Side Hatches - Poorly chassis and bulkhead. (SORNd)
2013 Defender Puma Utility XS
Post #1056885 10th Jan 2025 12:57pm
jst
Dry the locks. Or prewarm a key to insert to manipulating lock after unlocking with remote. Unlocking on remote and locks bouncing shut again is common in the cold Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1056900 10th Jan 2025 2:38pm
Dorothy
Cheers. Another 'Landy Special.
How much rotation should their be in one of those door locks? I only have Driver and Rear barrels on the Utility so I should replace both and I imagine the ignition. 2001 Defender Special Vehicles TD5 Hardtop (Ex Scottish & Southern) Side Lockers, Side Hatches - Poorly chassis and bulkhead. (SORNd)
Post #1056911 10th Jan 2025 3:23pm
