Home > P400e Area (L663) > Terrible range in Winter |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3789 |
Hello
We have just purchased a P300e Evoque and I charge this at home currently on a 3pin plug from 12.30pm to 5am In the morning it says 31 miles, 100% (I realize its a slightly different engine / motor) Is it full when you go to the car park to charge up? as if its only charging at a 3pin plug rate it will take a while.. |
9th Jan 2025 1:27pm |
Kevzpolo Member Since: 18 Jul 2024 Location: UK Posts: 4 |
I charge to full or 80% and pre-condition.
For example I may finish charge at 9pm, drive 1mile home then wake up and see the percentage drop to 65%. |
9th Jan 2025 1:29pm |
Having all the features on in this weather will affect it...
Seats, wheel, etc etc Its funny I'm on some Tesla forums and VW Buz ones as was looking at both for a swap, the range people are seeing are horrendous at the moment (like 70 miles with 50%) on the VW People suggesting, turn the heating down, the seats off etc etc... I mean come on, I didn't have the options fitted so I don't use them. I guess these temperatures are bad for UK (-5 today) so everything is being used more. I would wait until it warms up a bit to see if it gets better. It does sound like something is using more than it should? Do you set it to warm up etc before you get on the car? Will keep an eye on ours also. As for your lead I only paid £70 for the JLR granny charger off e-bay, genuine product then moved to an ev tariff, so car and batteries we have charge over night at 7.5p kwh I will have a charge point fitted as they are clever and in summer will divert the extra solar to the car |
9th Jan 2025 1:58pm |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5878 |
Welcome to the world of:
a. Land Rover electrics b. Electric Car ownership (esp in cold weather) c. Both of the above Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
9th Jan 2025 2:31pm |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 785 |
The brutal reality of EV tech?? |
9th Jan 2025 2:50pm |
Philm Member Since: 19 Jun 2020 Location: Manchester Posts: 173 |
need electric heaters to warm them up
9th Jan 2025 4:05pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1118 |
When the dailies that live outside freeze over I throw in a 1.5kw electric heater to pre warm them up. Then when you drive away you have 10min until the engine heats up and it's not as if the car had warmed up sufficiently.
So on an electric car ALL heating is electric, I would think you need 3kw and an electric car battery is like 30-40 kWh?, so that's an additional 10% capacity lost per hour? |
9th Jan 2025 6:37pm |
ardevd Member Since: 04 Mar 2024 Location: Norway Posts: 41 |
A PHEV makes very little sense if you don’t have a charger at home. The already limited range is impacted severely when the battery is cold.
18th Jan 2025 11:18am |
