![]() | Home > Technical > Defender Headlights |
revd Member Since: 20 Apr 2024 Location: England Posts: 219 ![]() ![]() |
Third time this week this has come up. Same problem here-Td5 - replaced column stalk and main switch (genuine Land Rover ££ ouch) all good now
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1218 ![]() ![]() ![]() |
Worth buying a relay loom. Easy to fit (and remove) and brighter lights too! Cheap and spares your switch
Navigator11 Member Since: 07 Jan 2025 Location: Gloucestershire Posts: 3 ![]() ![]() ![]() |
Thanks for the replies. I have changed the wiring loom (Boomslang) to get separate relays for each headlight and the light switch and column switch are less than 2 years old - hence I am looking at other options
