Home > In Car Electronics > Defender 90 radio not working.
JB2001
United Kingdom 2009 Defender 90 Puma 2.4 HT Indus Silver
Hi all,
New to the group and new to owning a Defender 90. I’m currently sorting out some of the problems with our 2009 model but we have 1 I can’t quite conquer, the radio. The radio has power as it will light up when the lights are on however that’s as far as it goes, no sound, small display screen won’t come on and won’t accept CDs. It is the original Land Rover head unit.
Have searched the forums and tried the usual things but nothing will work, hopefully someone will be able to help.
Thanks in advance.
James
Post #1056404 5th Jan 2025 6:33pm
Fataitch
United Kingdom 2010 Defender 110 Puma 2.4 PU Portofino Red
Having had to creat a new loom for the audio on my 2010 Puma, the illumination is a separate wire, so you also need a permanent live (to retain the radio presets) and a switched live so it goes off and on with the ignition - apologies if you already know this.
Check fuses first in the fuse box by your knees, then try a multi meter on the connectors at the back to see what you’re getting.
The std speakers aren’t great - most of my audio wiring and hardware had been ripped out prior to my ownership, but the speaker that did remain didn't work.
Post #1056415 5th Jan 2025 9:11pm
Fataitch
Just read again - it’s also possible a CD has been left in but won’t eject without the correct power supply.
At that back of the head unit, you should have an ISO block - 2 similar looking connectors that fit into 1 block - 1 for speakers, 1 for power etc. If the head unit has been changed in a previous life, some after market head units require the power inputs to be switched over, so just possible this needs swapping back.
Post #1056417 5th Jan 2025 9:15pm
It could just simply be the rear power connectors being loose and locking tabs not engaged.
Possible anyway, worse case scenario the HU itself is not well in itself so to speak. No Guts, No Glory.
Post #1056420 5th Jan 2025 10:33pm
