Home > Technical > Diff Lock Lever won't engage
Simon27
Scotland 2009 Defender 90 Puma 2.4 SW Tamar Blue
Hi All
In the recent snow I could have really done with the diff lock, but when I went to try it the lever would not budge at all.
High and low range shift smoothly but there is less than 1cm of slack in the lever when trying to push it to the left and then nothing at all.
The picture below shows the linkage which I have been spraying with WD40 but hasn't shifted yet. There is small movement at the link where the green arrow is as it takes up the slack, but then no movement between the link and where it goes into the transfer case.
Is there anything else I can be doing to free this up? By the general condition of the Land Rover I don't believe the diff lock has ever been used in the past 3 years by it's previous owner.
Post #205543 26th Jan 2013 4:20pm
jst
move it manually off the spigot, Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #205614 26th Jan 2013 7:33pm
Simon27
It turned out to be determined not to move but got it going now, all with the help of new my patented tool:
Diff lock light also turned on immediately and got it to disengage too.
Post #206242 28th Jan 2013 3:14pm
SimonR
You beat me to it!
They seize up when not used - but generally a hammer then regular use sorts it out!
Si
Post #206273 28th Jan 2013 6:29pm
mk1collector
You want to patent that quick before a Landrover exec hands it in as his own work!!
Post #206274 28th Jan 2013 6:31pm
Tom89..
Out of curiosity, what did you use the whacking tool for? My selector was on the wrong way due to a garage, spun that 180 today and out back together but now it's seized solid so your way may help me!
Post #1056232 3rd Jan 2025 7:58pm
