Home > Puma (Tdci) > Poor running and temp gauge drop
rover
Hi all,
My defender 2.2 tdci is intermittently running terribly.
Symptoms are, hesitant, surging, rattly noise from engine and a temperature gauge drop from normal to a quarter then back up to normal. The rattle, hesitancy and surging coincides with the temp drop.
I have changes the fuel filter, coolant, heating working fine, water pump seems to be working fine as pressure out of the bleed valve near the heater matrix.
Its getting worse and more often however it occasionally runs fine.
I have checked the error codes using a simple reader and non shown.
Help would be appreciated.
Regards,
Rover
Post #1056193 3rd Jan 2025 12:03pm
MK
Not sure if a dedicated tool will show other TDCs.
Have you checked connection for the coolant sensor?
Any means to look at the EGR operation?
Fuel filter condition
Battery connections
And the rest of the egine sensors. Puma 110" SW
Post #1056205 3rd Jan 2025 2:49pm
rover
Hi MK,
Thanks for the reply, I have changed the fuel filter, checked battery connections.
I am trying to book it in for a diagnostics technician to look at but the Christmas Holidays have not helped.
I'm hoping its something silly and cheap.
Regards,
Rover
Post #1056209 3rd Jan 2025 3:41pm
rover
Hi,
I thought I would post about the solution to the poor running and temperature gauge issue.
I took the car to HRS Diagnostics in Holme on Spalding Moor, Yorkshire. He diagnosed a faulty Temperature sensor and replaced it. Now running well.
I can thoroughly recommend Steve at HRS Diagnostics, he is a Defender owner and Land Rover enthusiast too.
Regards,
Rover
Post #1057345 14th Jan 2025 1:16pm
Ianh
Good he found the fault, which is the first time I’ve heard of that sensor going faulty.
As a bit of background.
The 2.2 does have a dedicated coolant temp sensor, unlike the 2.4 which uses the measurements from a cylinder head temperature sensor as a proxy for coolant temperature.
The 2.2 does not have a CHT sensor.
Sounds like the coolant temp sensor was faulty. See part 8 for its location.
Post #1057348 14th Jan 2025 1:48pm
rover
IanH,
It was indeed the coolant temperature sensor, part 8 on the illustration.
Regards,
Rover
Post #1057647 17th Jan 2025 12:38pm
