Home > General & Technical (L663) > DPF cycles - what is normal?? Advice needed!
Soup Dragon
Hi all,
I have A MY2024 D250HSE and have had DPF issues from day 1 of ownership (11 months).
Experience:
- typically DPF cycle kicks in every 20 minutes for around 6-7 minutes
- doesn’t matter how I drive or for how long, the same thing happens
- mpg is trashed. I have the trip computer set to instant mpg - when DPF cycle is on, mpg literally halves. So if 40mpg on a level road is the norm, it will do 20. Calculated to have cost me an extra £200-300 in fuel over the year
- DPF tell tale signs - stop start disabled, change of engine note, smell outside, instant fuel consumption (biggest giveaway)
- Owned a previous MY 22 Defender with same engine - no issues
What have I done:
- Asked my dealer to investigate at same time as having the oil changed at 12k miles. They didn’t have a clue. Jack of all, masters of none.
- Downloaded trip history from the App, reaffirms my view that I do a mix of driving and not over biased towards short journeys. I provided this data to the dealer
3 questions:
- Is DPF regen every 20 minutes ‘normal’?
- How to fix it once and for all if indeed that’s possible - can / should it be cleaned out under warranty?
- Would roadside assist staff have more expertise (would save me 2 hours travelling to / from dealer) or can the dealer approach JLR to request specific technical experts to assist?
Thanks in advance
Post #1055896 30th Dec 2024 12:23pm
lightning
That's not normal at all. My DPF regeneration occurs once every few days (all my driving is local)
D250 same as yours.
During the regeneration the MPG is indeed trashed, and it lasts 20 minutes. But l only get one every so often. And l use the vehicle all day every day.
lt sounds like your regeneration isn't completed so it keeps trying again.
When the regeneration starts, do you let it finish? lf you don't it will try again next time you use the vehicle.
On mine l don't need to drive in a particular way to allow the regeneration. lt will complete even if l am sat in slow moving traffic.
Try calling out Land Rover Assist. l have found them to be very good.
Post #1055906 30th Dec 2024 2:25pm
Soup Dragon
Thanks Lightning, useful to know and I appreciate sharing your own experience.
I called Land Rover Assist and one of their senior technicians will call round tomorrow morning. Let’s see what they have to say!
Post #1055944 30th Dec 2024 8:40pm
Soup Dragon
So had the LR Assist person visit this morning:
- he can find no recorded fault when plugging in his laptop. Without this, he’s not able to take any further action
- he did perform an engine reset of some kind (on his laptop) which should restore everything engine related back to factory settings, I’ll know in the next few days if that’s made any difference.
- he suggested it might be worth filling up with high octane / super diesel to see if that helps (especially after the engine settings reset). Also to try fuel additive (Millers or equivalent). I suspect both measures would improve fuel consumption (at a cost) but I’m skeptical whether it would fix the DPF issue. Worth a try?
The DPF unit is hard to access - LR Assist guy thinks it might be a case of engine out. So if they agree to do this and find no fault that can be claimed under warranty, then I’m liable to be charged a four figure amount? Would be cheaper to ignore and accept poor mpg!
Next steps
1. Wait to see if the engine reset has cured the issue (not holding my breath)
2. Try super diesel and additive for a few weeks
3. Contact dealer and ask them to take another look. I suspect without a fault being registered, we’ll be going around in circles - even if I take the technician for a drive and show him when the regen is happening.
4. If still no joy, contact JLR Customer Services.
I looked online - the AA state regen should occur every 300 miles. Mine occurs every 15 miles so 20x more frequently…
Lesson learnt - don’t buy a JLR diesel. I accept mine might be quite a rare fault but would not want to go through the same experience again.
Post #1055977 31st Dec 2024 12:28pm
lightning
Have you got the Land Rover Remote app for the vehicle. What does it say under "DPF". Does it say "clean & efficient"?
Post #1055980 31st Dec 2024 1:11pm
Soup Dragon
Hi Lightning, yes that’s the message I have too - clean and efficient. Which clearly is not the case. If the sensors are not picking up a problem, then as far as the car / App is concerned (and therefore the dealer), there is no problem.
Post #1055981 31st Dec 2024 2:11pm
lightning
Set your MPG to "average" and see what it records over a few days. My guess is it will be under 20mpg (my average in local driving is 26)
lf you are below 20mpg that's a case for returning the vehicle to the dealer as it's clearly showing a there's an issue with it.
An alternative would be to take the vehicle to an independent Land Rover specialist and get them to have a look at it.
l see you are in "Cheshire"
There's a very good one in Hayfield called Hallam Brothers. (not Jim Hallam in Leek)
My guess is, that some sensor is not working or has not been connected as it's done it since new. So it's constantly telling the ECU to regenerate the DPF
The DPF is almost certainly "clean & efficient" in fact you'll probably have the cleanest DPF in town.
Post #1055982 31st Dec 2024 2:26pm
barbel jim
No I think I have the cleanest DPF in the uk!
I know it’s not the same vehicle but I’m currently having this issue or similar on my 4.4 sport.
The short answer is no it shouldn’t be doing a regen that often. Mine appears to be constantly. After some persistence with my main dealer service manager, and basically backing him into a corner, he’s agreed to an investigation, fixed price. Nothing shows on the electrical side, plugged in diagnostics show everything normal, so basically there’s an underlying fault. Consensus of opinion is overfueling probably caused by an air leak, which in turn means more soot produced hence all the regens. Mine has been highlighted by the service due counter tumberling. Eg yesterday the wife’s commute 27 miles reduced the service due count by 451 miles Rolling with laughter interesting though, although she’s done another 70 miles, the service due hasn’t moved !!! It’s only done 2000 miles since they serviced it end of November. In control app shows clean and efficient, with no issues. It’s booked in 14th jan so we’ll see what they find.
Reading many other posts on the subject, split intake hoses have been mentioned more than once.
I think you should be back at the dealers door…. Yes potentially expensive, but LR will not give you any gesture if you don’t go through the motions
Post #1055984 31st Dec 2024 2:48pm
Gareth
I think you should be keeping a fuel log. Record brim to brim and miles actually driven over a period of time. Fuelly app is useful for this. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #1055989 31st Dec 2024 3:35pm
lightning
A DPF regeneration takes around 20 minutes on mine, when it happens (slightly higher idle speed is the only real indicator)
lt happens once every few days of local driving, around every 100 miles.
Post #1058652 26th Jan 2025 3:04pm
Soup Dragon
Well I think I’ve cracked it!
Went back to my dealer today for the second time to see if they could fix the DPF issue. A quick recap:
- They couldn’t find anything on the first visit due to no fault codes showing up
- I then called out LR Assist to see if they had any ideas - same story, no fault codes so can’t do anything
- Spoke to the Service Manager. Explained the issue in detail. He gave me the impression that he didn’t believe me and suggested it was my driving style, too many short journeys bla bla and “you’re lucky to get 32mpg”
- swapped to Super Diesel ever since but it’s not made much difference
This time when I dropped the car off today I spoke directly to one of their senior technicians and he took a real interest. He’d not seen this before but I knew he was going to be much more methodical / forensic.
The outcome:
- the issue was caused by a split air intake hose where it goes into the airbox, this would have been faulty at the factory. This made things too hot, causing a build up of soot, hence the excessive DPF regens. The air leak was messing up the correct air:fuel mixture but wasn’t enough to trigger a sensor
- the technician was also able to download a lot more data to show when the car was doing a DPF cycle, it backed up my own observations about it occurring every 20-30 mins
- A nice surprise was that I received a £150 hotel voucher for the trouble I’d been put through, which was a nice gesture and other dealers may not have been so generous!
I feel vindicated. After many months of waiting for a resolution, I’m now able to get a decent mpg out of the car. It’s probably cost me £500 in extra diesel.
Post #1062234 6th Mar 2025 10:36pm
DrRob
Result Bow down
Glad to hear there are still some decent technicians out there with a customer focus Thumbs Up MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie"
Many Range Rovers and Land Rovers over the years 😂
1949 80" - still in family since 1975
Post #1062239 6th Mar 2025 10:47pm
DFNDER
Australia
Good result, well done for persevering and that the tech actually wanted to help.
Split intake hose / ducts are more common than not, these parts are usually rigid plastic, installed cold and clamps done up by electric or powered drivers, leading to cracks etc.
Post #1062246 7th Mar 2025 2:13am
