![]() | Home > General & Technical (L663) > DPF cycles - what is normal?? Advice needed! |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2949 ![]() ![]() |
That's not normal at all. My DPF regeneration occurs once every few days (all my driving is local)
D250 same as yours. During the regeneration the MPG is indeed trashed, and it lasts 20 minutes. But l only get one every so often. And l use the vehicle all day every day. lt sounds like your regeneration isn't completed so it keeps trying again. When the regeneration starts, do you let it finish? lf you don't it will try again next time you use the vehicle. On mine l don't need to drive in a particular way to allow the regeneration. lt will complete even if l am sat in slow moving traffic. Try calling out Land Rover Assist. l have found them to be very good. |
Soup Dragon Member Since: 22 Sep 2023 Location: Cheshire Posts: 90 ![]() ![]() |
Thanks Lightning, useful to know and I appreciate sharing your own experience.
I called Land Rover Assist and one of their senior technicians will call round tomorrow morning. Let’s see what they have to say! |
So had the LR Assist person visit this morning:
- he can find no recorded fault when plugging in his laptop. Without this, he’s not able to take any further action - he did perform an engine reset of some kind (on his laptop) which should restore everything engine related back to factory settings, I’ll know in the next few days if that’s made any difference. - he suggested it might be worth filling up with high octane / super diesel to see if that helps (especially after the engine settings reset). Also to try fuel additive (Millers or equivalent). I suspect both measures would improve fuel consumption (at a cost) but I’m skeptical whether it would fix the DPF issue. Worth a try? The DPF unit is hard to access - LR Assist guy thinks it might be a case of engine out. So if they agree to do this and find no fault that can be claimed under warranty, then I’m liable to be charged a four figure amount? Would be cheaper to ignore and accept poor mpg! Next steps 1. Wait to see if the engine reset has cured the issue (not holding my breath) 2. Try super diesel and additive for a few weeks 3. Contact dealer and ask them to take another look. I suspect without a fault being registered, we’ll be going around in circles - even if I take the technician for a drive and show him when the regen is happening. 4. If still no joy, contact JLR Customer Services. I looked online - the AA state regen should occur every 300 miles. Mine occurs every 15 miles so 20x more frequently… Lesson learnt - don’t buy a JLR diesel. I accept mine might be quite a rare fault but would not want to go through the same experience again. |
Have you got the Land Rover Remote app for the vehicle. What does it say under "DPF". Does it say "clean & efficient"?
Hi Lightning, yes that’s the message I have too - clean and efficient. Which clearly is not the case. If the sensors are not picking up a problem, then as far as the car / App is concerned (and therefore the dealer), there is no problem.
Set your MPG to "average" and see what it records over a few days. My guess is it will be under 20mpg (my average in local driving is 26)
lf you are below 20mpg that's a case for returning the vehicle to the dealer as it's clearly showing a there's an issue with it. An alternative would be to take the vehicle to an independent Land Rover specialist and get them to have a look at it. l see you are in "Cheshire" There's a very good one in Hayfield called Hallam Brothers. (not Jim Hallam in Leek) My guess is, that some sensor is not working or has not been connected as it's done it since new. So it's constantly telling the ECU to regenerate the DPF The DPF is almost certainly "clean & efficient" in fact you'll probably have the cleanest DPF in town. |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 ![]() ![]() ![]() |
No I think I have the cleanest DPF in the uk!
I know it’s not the same vehicle but I’m currently having this issue or similar on my 4.4 sport. The short answer is no it shouldn’t be doing a regen that often. Mine appears to be constantly. After some persistence with my main dealer service manager, and basically backing him into a corner, he’s agreed to an investigation, fixed price. Nothing shows on the electrical side, plugged in diagnostics show everything normal, so basically there’s an underlying fault. Consensus of opinion is overfueling probably caused by an air leak, which in turn means more soot produced hence all the regens. Mine has been highlighted by the service due counter tumberling. Eg yesterday the wife’s commute 27 miles reduced the service due count by 451 miles ![]() Reading many other posts on the subject, split intake hoses have been mentioned more than once. I think you should be back at the dealers door…. Yes potentially expensive, but LR will not give you any gesture if you don’t go through the motions |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1116 ![]() ![]() |
I think you should be keeping a fuel log. Record brim to brim and miles actually driven over a period of time. Fuelly app is useful for this. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy |
A DPF regeneration takes around 20 minutes on mine, when it happens (slightly higher idle speed is the only real indicator)
lt happens once every few days of local driving, around every 100 miles. |
