Home > Puma (Tdci) > Genuine Sidesteps Rivet Size after Powder Coating.
roche1800
Hi, does anyone know the LR type of rivet for the side step.
I have stripped them and had the sand blasted and powder coated and want them to be identical.
The drilled holes are around 7mm so would it be a 6.4mm rivet by say 20mm long.
I would really like to know what size was originally used? Cheers
Post #1053925 5th Dec 2024 5:37pm
MartinB
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
I installed rivnuts and held the aluminium plate in place with M6 dome headed stainless screws. I am not too far from you. Where did you go for powder coating?
Post #1055800 28th Dec 2024 6:47pm
philippr86
Germany
I don't remember the exact size of rivets for those, but in the end I did the same as Martin, going for the next lager size of Rivnuts and bolting the aluminium back on. Couldn't find properly sized rivets anywhere...
Post #1055840 29th Dec 2024 2:32pm
Vitesse
Try GESIPA on Google. They supply the original rivets Thumbs Up 2015 90 XS Santorini Black
Post #1057883 19th Jan 2025 6:08pm
Erik256
Estonia 2007 Defender 110 Puma 2.4 SW Keswick Green
Great tip! Do you know by chance which one is the original rivet? There are quite many to choose from.
Post #1058955 30th Jan 2025 8:44am
Vitesse
I have managed to contact the company and they are helping out. They recognised the item but has been out of specific use for some time. The OEM side steps manufacturer had a special version made for them. I suspect a different type of rivet would work. Interesting to see what they come back with. 2015 90 XS Santorini Black
Post #1058960 30th Jan 2025 10:03am
Erik256
I would greatly appreciate, if you would post here the info, when you find out. I'm contemplating on refurbishing my side-steps, but not finding the correct rivets has so far held me back.
Post #1058961 30th Jan 2025 10:07am
