![]() | Home > Td5 > No starting engine temperature gauge reads high |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5833 ![]() ![]() |
Run a new earth to where the underseat fuses and relays are. Even just a temporary one for a test.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6647 ![]() ![]() ![]() |
Sounds like ECU not "on". Need to check power and grounds at ECU black plug, and the ignition "wake up" feed.
Grounds: Black Main Power: Brown/Orange (but will only be live with ECU plugged in and switching on main relay, difficult to test it unplugged) Wake Up/Ignition: White/Green You'll need a multimeter to check continuity to ground/battery negative for the grounds, and voltage to ground/battery negative for the power/ignition. ![]() ![]() |
Printerjohn Member Since: 12 Mar 2024 Location: Poole Dorset Posts: 26 ![]() ![]() ![]() |
Looking like an electrical problem from the hidden security switch fitted by a previous owner.
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 149 ![]() ![]() ![]() |
Have you resolved this one?. I have had a similar one with the temp straight to red, even with a cold start. Fuel pump silent. Fixed mine with a new fuel pump relay under the drivers seat. It was sticking. I did manage to start up simply by giving the relay a tap with a screwdriver. Happy to send a pic of which one if you would like me too cheers
Problem sorted, I think the fuel cut-off switch must operate on the fuel pump relay, hence the temperature reading high when the engine is not running.
