Home > In Car Electronics > What does this mean ?
Fataitch
United Kingdom 2010 Defender 110 Puma 2.4 PU Portofino Red
Evening all, I’m trying to find the source of an electrical issue that has caused the loss of my dipped beam on LED headlamps. All other lighting operating as normal.
Can someone tell me what’s this refers to please ?
Labelled as C1264-2, C1265-2, C1266-2, C1267-2 - is it a junction box or some other connection ?
As said, I’ve suddenly lost my dipped beam, both sides. I’ve replaced the relay and column switch (which is getting power), without improvement. At the headlamp end, I get sidelights (12v ish across the connector) but no voltage when I switch to dipped beam.
I’m losing power somewhere after the column switch.
I don’t know what the symbols in the diagram refer to, so hoping this is a connector that I haven’t found yet.
Any help appreciated.
Thanks
Hayden
Post #1055140 19th Dec 2024 6:09pm
It's a connector block mounted on the bulkhead behind the radio where the dash harness joins the engine bay harness. It is extremely inaccessible and is a dash-out job to access.
Post #1055143 19th Dec 2024 6:31pm
Fataitch
Thankyou for that., Blackwolf !
Not the greatest news Shocked
Post #1055146 19th Dec 2024 6:47pm
The issue could be stalk related, the master switch is one side of it, but I seem to remember that there is contacts on the stalk that are used too that the dipped also uses and the pins and connections can get damaged or a connector popped off.
Though the stalk does engage main flash or locked main beam, I seem to remember dipped goes through there too.
Alternatively it could be just the master switch that has burnt out, which is common.
Taking a look, and testing with a Multimeter is ideal.
My guess is one of these two, rather than anything external.
If you do take the stalk assembly off, don’t over tighten the collar on the steering column, just lightly nipped up or it will shear then you’ll have a loose indicator / wash wipe assembly.
If you don’t have a DMM (multimeter) visually check those pins when the switching is activated that they are making contact, and you can bridge if anything looks suspect to see if that does the trick.
Check for any pins that might have the female side pop off, as it can happen by accident installing, they often aren’t that tight from the factory. Rolling Eyes
If everything was okay before the installation, those things are suspect little else I’d be 90% sure on that. TheThunder Rolls🇬🇧🇺🇸
Post #1055147 19th Dec 2024 6:53pm
Fataitch
Custom90 - fairly sure I owe you a beer. Blackwolf worried me into checking again before I take the dash out, so I removed the column switches again, cleaned all the contacts and refreshed all the connections and BOOM !!! Lights working again.
Thankyou both, very much appreciated.
Hayden
Post #1055179 20th Dec 2024 12:37am
Just to supplement my post above, below is a photo of the box containing the aforementioned connectors (note that the photo is of a left-hand drive vehicle). The connectors are in the long black plastic object in the upper centre of the photo (conveniently placed so that if the screenwasher pipe comes off its spigot the discharge will enter the head box and cause all manner of weird electrical malfunctions - ask me how I know!).
The vehicle in the photo has had the dash, heater, heater/demister ducting, and main dash support bar removed. Far from a trivial job (although the heater itself doesn't need to come out to access the connector box). The good news is that on the whole the headers/connectors are quite reliable.
I thought the picture was worth posting since photos of this object are fairly rare, for obvious reasons.
Post #1055192 20th Dec 2024 9:17am
I remember seeing that, LR packed the whole loom through there pretty much except a few others on the chassis rail insides.
The washer jet and the attached pipe, and the Barb on the jet, I’m surprised they don’t come off more often, the jet it drive is a pain to change anyway.
I’d suggest if anyone has the centre dash out and the washer jet is getting on a bit to change it whilst there, it’s a pain to do on its own so worth doing.
Regards, the OP (Fataitch) No worries, guess how I know too I had a similar issue before and it was a headache for a week or two I can tell you. Laughing
I traced it in the end, turns out it happens to other LR’s too.
I believe it’s normal transmission vibration a lot of it, it’s common with Defenders not to mention the arduous conditions.
Glad it’s sorted. Thumbs Up TheThunder Rolls🇬🇧🇺🇸
Post #1055196 20th Dec 2024 9:48am
Fataitch
Blackwolf & Custom 90
You have no idea how useful that pic is. I’m finding so many things that have been cut out of the loom and left dangling (due to a “conversion’ from SCPU to soft top).
I was a little worried as I’d been running some new speaker cables and stereo wiring through. I was really careful but still panicked when blackwolf mentioned the stereo area Laughing
I think I now have the essentials to survive, all working properly. I’ve also discovered I have an AS10 unit and an immobiliser ring around the ignition. I’d quite like a working immobiliser but not sure how much hassle reinstating the LR one will be.
Thanks both
Hayden
Post #1055228 20th Dec 2024 4:58pm
