Home > Technical > DPF differential pressures & other info |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 531 |
Not sure exactly what you mean by concerns..given your differential pressure is low..
We had a discussion on this topic a while back on a thread and think its safe to say you don't want to be getting wound up by the scan tool data on % soot loads as long as you are regenerating and it falls .. The pressure across the unit is a far better guide .. My torque app did give temp readings on the exhaust but sorry I can't remember if it gave the differential pressure data..it is listed in the data available , but can't remember viewing it.. |
19th Dec 2024 12:42pm |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 497 |
DPF fills up and burns out : 20 ... 90% in one cycle That's for normal use. You're @28K - so your DPF will be fine for another 100K - at least You cannot deduct its life expectance from sensor (ECU) data. But you may display these data with a Nanocom. |
19th Dec 2024 1:48pm |
