Home > Maintenance & Modifications > Needle scaler |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20588 |
Do you mean for removing rust / corrosion etc? If so, I think there is but normally air powered I think.
Mechanical it’s normally wire brush etc, nylon paint discs can be good too but won’t get everywhere. Obviously PPE is a good idea with that. Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
18th Dec 2024 6:04pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17558 |
Hilti makes an electric needle-scaler which is an excellent tool but I don't know.of any others. The Hilti is expensive (£500 for the needle head alone, plus the £1200 cost of a compatible hammer), https://www.hilti.co.uk/c/CLS_POWER_TOOLS_...-kits-tabs
If you go down the air route I recommend Trelawney scalers since they are much quieter and lower vibration than any other I've used (which is many over the years) - vibration white-finger can be a real and life-changing problem with tools of this type. https://trelawnydirect.com/needle-chisel-scalers.html Hiring might be a cost effective option. |
18th Dec 2024 7:53pm |
julian Member Since: 17 Feb 2017 Location: Devon Posts: 138 |
Cheap air ones are available for not a lot at all.
But, of course, you then need an air compressor. |
18th Dec 2024 8:16pm |
Needle scalers (at least those large enough to be worth bothering with) tend to use quite a lot of air continuously. You need a reasonably large compressor to run one.
There is it seems an Italian firm that makes needle scaler attachments for SDS drills: https://www.ebay.co.uk/itm/156362567629?_s...R76cu7j7ZA |
18th Dec 2024 8:32pm |
I’ve seen them used before for military vehicle / tank resto before, ideal for getting in corners or over hot rivets and things like that, even steam machines, locos etc with old paint. Play Stupid Games, Win Stupid Prizes.
18th Dec 2024 9:22pm |
Naycrx Member Since: 11 Oct 2023 Location: Nottinghamshire Posts: 140 |
Yes we had the Defender waxoyl over a year ago .... but i have decided to start do small sections at a time on the chassis complete sand down Kurust - Zinc Prime and dinitrol - i have done a few parts - and really happy with the finish - I have ordered a Twisted wire brush and a normal one for the drill -
Feel I have started a Huge task But doing it in stages seems ok |
18th Dec 2024 10:40pm |
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 212 |
How much do you hate your Neighbours? They are loud but very good at what they do they will also find any weak spots on your chassis. Havent seen electric ones but that SDS attachment one looks ok probably cheaper than buying a decent compressor to run an air one 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
19th Dec 2024 5:30pm |
I don't know, but I suspect that using a needle scaler on anything other than ancient waxoil may end up in a horrible black gummy mess It may be fine, but my suspicion is that it will not be Before you burn too much of your life on it, be mindful that a lot of the corrosion comes from the inside face, and cleaning and painting the outside won't stop that. Solvents would do the job, but, it would be so messy and the risk of burning up the vehical in the process would be greater than "zero". But, again, a considerable amount of the damage is coming from the inside. |
19th Dec 2024 5:53pm |
MattBee Member Since: 29 Oct 2023 Location: Hampshire Posts: 9 |
The Hilti needle scaler fits onto any SDS that has a ‘chisel’ function.
You can find them second hand now and again on eBay but I’m generally wary of that as second hand Hilti is a bit like Landrover parts; invariably stolen. That aside it is a very good tool but very noisy! |
20th Dec 2024 8:13am |
