Home > Modifications & Maintenance (L663) > Retrofit front passenger seat Isofix Defender 90 |
I suspect your last sentence is the reason why LR didn't fit it in the first place. Obviously not a problem if you're aware of the limitation but LR can't take that chance. Darren
11th Sep 2024 12:28pm |
carltb Member Since: 06 Oct 2023 Location: Sweden Posts: 60 |
Yes, for sure that is the case. But for those who want to be able to have one there is nothing technically different with the seat to hold you back from installing one. Haven’t seen anything about it so just thought I’d let people know. 👌🏻 2025 Defender 130 V8 (DOA, new one coming)
2025 Defender 90 D250 (wifes) 2024 Defender 110 p400e HSE (sold) 2015 Defender 110 Double cab 2004 Defender 90 Td5 |
11th Sep 2024 1:22pm |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1186 |
...... and remember to remove the modification, when you move it on.
11th Sep 2024 2:45pm |
Worth pointing out is that it is actually easier folding the front seat forward when there is a rear-facing seat in it than if there is a high back booster seat... Not requiring isofix. So the decision from LR to skip isofix in the front in the 90 but not specifically advice against high back booster seats is interesting...
Difference is that you can slide the seat forward better with the booster seat but not fold it. So you won't get out from the back anyway. 2025 Defender 130 V8 (DOA, new one coming) 2025 Defender 90 D250 (wifes) 2024 Defender 110 p400e HSE (sold) 2015 Defender 110 Double cab 2004 Defender 90 Td5 |
11th Sep 2024 2:53pm |
n1allohara11 Member Since: 28 Nov 2024 Location: LONDON Posts: 3 |
Hi Carltb, where would I purchase an isofix bar? thank you.
28th Nov 2024 2:39pm |
Hi
I listed the part numbers in the first post. Good luck! 2025 Defender 130 V8 (DOA, new one coming) 2025 Defender 90 D250 (wifes) 2024 Defender 110 p400e HSE (sold) 2015 Defender 110 Double cab 2004 Defender 90 Td5 |
28th Nov 2024 3:40pm |
Hi Carltb, thanks for your reply. I have found the parts and decided to have a look under the seat before the purchase. I took off the side plate and lifted the fabric but cannot see where the 4 bolts would go. Perhaps this had now changed with the 2024/25 model I just purchased.
Thanks again for your help. |
2nd Dec 2024 11:13pm |
Davedig Member Since: 18 Feb 2024 Location: England Posts: 26 |
Made any progress with this? Dealer has evaded my question on the matter!
12th Dec 2024 6:53am |
Hi Dave, yes I managed to source a bar that fits and 2 bolts are needed. I see you’re in England so a different part number is needed for the RHD.
I purchased the cheapest I could find at duckworthparts uk Parts; LR089420] BAR - ISOFIX LR048645] SCREW X2 Here’s a video clip showing how to remove the side plate. A pretty easy task all in all. Good luck. |
18th Dec 2024 3:15pm |
Click image to enlarge found this photo, it shows what the ISOFix bar looks like once installed (not that I have done it) The 'ISOFix-buttons' will be more difficult to fit (although not needed if the fit is temporary) |
18th Dec 2024 6:35pm |
