Home > Modifications & Maintenance (L663) > Retrofit front passenger seat Isofix Defender 90
carltb
 2015 Defender 110 Puma 2.4 DCPU Corris Grey
So the Defender 90 comes without isofix mount on the front passenger seat as opposed to all other models Defender. In case anyone is interested I just bought and mounted one. LR dealer would not mount it. Liability issue or something.
Easy job not requiring seat out or anything. Just remove plastic outside cover (the one around the seat controls) that's clipped in place and with one screw. Then unhook the seat bottom back fabric with two hooks underneath seat. Lift up fabric and just slide the isofix bracket in place aligning with existing screw holes and fasten with four screws. Took 30 minutes.
Parts needed are
1pc - LR089419 Isofix bar
4pc - LR048645 Screw
Worth noting is that if you put a rear-facing seat in the front it will be harder to evacuate rear passengers in case of emergency. We will only be using the front isofix when there is no-one in the back. 2025 Defender 130 V8 (DOA, new one coming)
2025 Defender 90 D250 (wifes)
2024 Defender 110 p400e HSE (sold)
2015 Defender 110 Double cab
2004 Defender 90 Td5
Post #1045541 11th Sep 2024 12:05pm
I suspect your last sentence is the reason why LR didn't fit it in the first place. Obviously not a problem if you're aware of the limitation but LR can't take that chance. Darren
Post #1045545 11th Sep 2024 12:28pm
carltb
Yes, for sure that is the case. But for those who want to be able to have one there is nothing technically different with the seat to hold you back from installing one. Haven’t seen anything about it so just thought I’d let people know. 👌🏻 2025 Defender 130 V8 (DOA, new one coming)
Post #1045549 11th Sep 2024 1:22pm
LR Nuts
...... and remember to remove the modification, when you move it on.
Post #1045559 11th Sep 2024 2:45pm
carltb
Worth pointing out is that it is actually easier folding the front seat forward when there is a rear-facing seat in it than if there is a high back booster seat... Not requiring isofix. So the decision from LR to skip isofix in the front in the 90 but not specifically advice against high back booster seats is interesting...
Difference is that you can slide the seat forward better with the booster seat but not fold it. So you won't get out from the back anyway. 2025 Defender 130 V8 (DOA, new one coming)
Post #1045560 11th Sep 2024 2:53pm
n1allohara11
Hi Carltb, where would I purchase an isofix bar? thank you.
Post #1053217 28th Nov 2024 2:39pm
carltb
Hi
I listed the part numbers in the first post. Good luck! 2025 Defender 130 V8 (DOA, new one coming)
Post #1053225 28th Nov 2024 3:40pm
n1allohara11
Hi Carltb, thanks for your reply. I have found the parts and decided to have a look under the seat before the purchase. I took off the side plate and lifted the fabric but cannot see where the 4 bolts would go. Perhaps this had now changed with the 2024/25 model I just purchased.
Thanks again for your help.
Post #1053697 2nd Dec 2024 11:13pm
Davedig
Made any progress with this? Dealer has evaded my question on the matter!
Post #1054474 12th Dec 2024 6:53am
n1allohara11
Hi Dave, yes I managed to source a bar that fits and 2 bolts are needed. I see you’re in England so a different part number is needed for the RHD.
I purchased the cheapest I could find at duckworthparts uk
Parts; LR089420] BAR - ISOFIX
LR048645] SCREW X2
Here’s a video clip showing how to remove the side plate.
A pretty easy task all in all.
Good luck.
Post #1055013 18th Dec 2024 3:15pm
LR Nuts
found this photo, it shows what the ISOFix bar looks like once installed (not that I have done it)
The 'ISOFix-buttons' will be more difficult to fit (although not needed if the fit is temporary)
Post #1055045 18th Dec 2024 6:35pm
