Home > General & Technical (L663) > Taildoor Open From Key Fob
Chris_P
United States
I activated the taildoor remote open feature from the Smart Key (key fob), using the GAP iiD G4 tool. When I hit the Taildoor button the door pops ajar, but immediately the soft close feature shuts it.
Does anyone have a remedy to pop the door out of grasp of the soft close feature, so that it stays open?
Post #1054855 16th Dec 2024 3:26pm
CincyRovers1
United States
I had mine activated as well. You need to be really quick to grab it. Or, park on a slight descent, and it gravity will open it up. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red)
𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone
𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone
Post #1054857 16th Dec 2024 3:48pm
LR Nuts
I have a very early model. When I press the key fob, 'open tailgate' it releases the lock, then you have to pull the handle - door then opens. NO other doors or activation of vehicle systems happen.
Then when you shut the door the amber lamps flash and the door is locked.
Point of note - the back door has soft close, although that should not matter.
My vehicle has not been modified with a GAP Tool Smile
Post #1054860 16th Dec 2024 4:04pm
CincyRovers1
United States
Correct - that is how mine used to be before I activated the tailgate to release. It still only unlocks/releases the tailgate and locks automatically when shut. But when you activate the tailgate to release, it pops the door open, and if you don't grab it quickly enough, the soft close catches it and closes it. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
Post #1054861 16th Dec 2024 4:10pm
Chris_P
United States
I was hoping that it would allow the taildoor to open further as it would help allow someone to have access without unlocking all doors. Sounds like it really isn't any diffferent than unlocking it and opening or opening by pressing the button on the handle.
Wishful thinking...
Post #1054870 16th Dec 2024 5:45pm
Philm
I activated mine with soft close. It unlocks and opens slightly, but it does not close on soft close until I close it.
Post #1054878 16th Dec 2024 6:41pm
LR Nuts
watch this video..... from 11.00 minutes
this may help
Post #1054902 16th Dec 2024 10:07pm
Defendit..
Netherlands
You can adjust the 2 Rubber round bump stops, this allows the rear door to pop open. No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1054905 16th Dec 2024 10:09pm
Colin68
I have activated mine using the Gap tool. Mine opens about an inch and stays open.
MultiCAN-770 Remote Release Tailgate
Enabled
This will make the rear door pop open when you press the button on the key fob
Post #1054923 17th Dec 2024 7:32am
Chris_P
United States
Well it looks like mine now will ajar just enough to not self close. I wonder if it has anything to do with the vehicle needing to go through a few shut down cycles to get right but works like it should.
Post #1054937 17th Dec 2024 11:47am
Defendit..
Netherlands
Adjust the rubber bumpstops anti clockwise a little bit till it works.
Post #1054982 17th Dec 2024 8:55pm
