![]() | Home > My Defender > Defender 110 - True Height In Car Park at Gatwick South |
jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 182 ![]() |
I was in Gatwick south a few weeks back - the valet parking appeared to be in one of the multi-storey car parks (there's 4 or so, identified by colour).
I'm not sure on the height restriction (I wasn't in the Landy), but the spiral ramp to change between floors is *very* tight - with a 110 with a big turning circle it could be a challenge.. I'd probably put it in the long stay parking... |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2257 ![]() ![]() |
I would not go into a car park that quoted such a low max height. Human error plays a big role in these things and even if the max height is correct for the car park when originally built , including when going up slopes etc. People can subsequently fit items to the ceilings, or ceiling fittings can drop, and if your defender height is correct ( seems low to me) then you only have 30mm to play with !!
For me the risk is too high, “ Act in haste, repent at leisure” . |
Crazymind Member Since: 11 Jun 2024 Location: Glasgow Posts: 248 ![]() ![]() |
You shall be fine. Lower the suspension and you’ll get more top clearance. Usually parking quote 2mt but it’s 2.05 mt. If something goes wrong it’s on them…
Jonathanhu22 Member Since: 13 Dec 2024 Location: Midlands Posts: 5 ![]() ![]() |
Thanks
When you lower it, how much lower does it go? |
